Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Water problems seaco Italia
I am having a similar problem
the water comes out odf the wand but not thru the coffee
Could you please let me have the bike pump instruction!
thanks
sincerely
marc pearce
  • marcpearce Jul 20, 2008
    ok found the problem
    the machine was grinding, tamping and there was water in the tank which came ouyt of the wand
    Just the final push through spout was not working
    so i took out the brew unit and followed the rubber tube that takes the coffee throught the spout to the cup.
    After removing the screws holding it in place I removed the spring and cleaned the piece. There was a build up of coffee around the spring.
    I put it back together and it works perfectly again !
    I love this machine. I have had it for la long time and every now and then it challenges me like this!
Glad you found where the blockage was. Another trick to ensure that this problem does not occur is to "fake the machine" by setting it to do ground coffee without you putting any ground coffee. This way, the machine will basically run hot water through the lines you just cleaned and will help to keep it cleaner. You can find some more maintenance tips at: http://www.coffeetico.com/saeco_espresso_machine_maintenance.htm
Posted on Jul 21, 2008
  • 40 Answers
Have you professionally cleaned the grinder ( + burrs)? To do this, would have to open the machine, remove the burrs, & clean them.
Posted on Jul 17, 2008
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
My Saeco Digital Italia stream/hot water wand quit working. When I press stean and turn the knob it pops out (not off) and nothing comes out. Hot water also want come out.
Push in on the knob when it pops out if that works then the steam valve assembly needs to be replaced, ask for the stainless steel valve replacement.
Mar 11, 2011 | Starbucks Saeco Italia Digital Barista...
Cannot prime pump.
I had the same problem, found the steam wand was plugged. You can screw the wand off (the crome metal tube) and then open the water valve. If you have flow take a wire and clean out the wand and your good to go.
Dec 08, 2010 | Starbucks Saeco Italia Digital Barista...
I have a Seaco Royal Professional coffee machine and it is telling me to ventilate, what does this mean and how do I fix this problem?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out. This mean that any steam or air blocked in the water system must get out from steam wand.
Good luck
Jul 26, 2010 | Saeco Royal Professional Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
The two coffee lights and the water light are flashing
Had the same problem. I sealed my lips around the steam wand and sucked as hard as I could, first with open steam knob, then with closed. Obviously there was some air left inside from steaming before. Machine worked fine afterwards.
Nov 30, 2009 | Starbucks Saeco Italia Digital Barista...
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
No water through the dispenser
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
try this link if it cant help u fix the problem it can direct u to someone who can
Nov 30, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
107 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
