Question about Refrigerators
The compressor goes to start then cuts out - Refrigerators
  • 4,070 Answers
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Posted on Dec 29, 2010
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
Frcapacitor
does the compressor have thermal overloads?
that might be part of the issue if it does not want to restart for awhile.
Aug 15, 2013 | Samsung Refrigerators
My rv air conditioner goes on only about a minute then pops the fuse, why might this be? and hoiw do i fix it?
This might be the relay cutting out. Try feeling of the compressor after it cuts off.If its getting too hot to hold your hand on then you either need a relay(Hard start recommended- Ask your parts dealer.) or the compressor is shorting.
Aug 19, 2010 | Dometic Rooftop RV Air Conditioner
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
Dometic Duo Therm Ac, Fan runs, Compressor cuts in and out?
your compressor is locked up. i would try replacing the round start capacitor. you need to check what the exact rating for yours is but I believe one of these two will work for ya. In the meantime do not continue to try to run it, it will kill the compressor.
seth
53-64 mfd
45-53 mfd
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Fan turning on and off , not sure about compressor
its the compressor relay thats clicking[its a little unit connected to compressor with at least two wires]it could be that its [relay]going bad or the compressor could be failing,but it dose cool once it gets started so thats a good sign.the relay has two parts.one an over load,thats like a curcit breaker,it cuts power to compressor if its drawing to much amparage.the other part is a swith that goes fro start winding to run winding.as a repairman i would pull relay and use volt meter to check winds before replacing relay.its been alittle while but depending on age of refer,start winding around 2.7+-.5run winding 1.1 +- .5 new box use less energy so lower resistance older higher.hope that gives you a start ps fan goes off on because its starts with compressor.God bless ,tom
Jan 06, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Small refrigerator compressor overload relay cuts out
I am told if you measure two terminals and note the two with the highest resistance. Then measure each of the two terminals with the highest resistance to the common terminal they the two additional readings should read the same as the two terminals with the highest resistance when adding them together. If after adding the two there is more than 1/2 ohm difference one of the windings is shorted.
Nov 25, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
I think that I have over charged the freon in my car and the air goes back and forth from warm to cold
if you over charge it it will do exactly what you describe when you start the compressor the pressure goes up up up to a point the sensor on the line cut out the compressor pressure goes down start over again if you dont have gauge to see the pressure start everything remove some gas untill you see the compressor stsrting if compressor stay on its enought thanks pierre
Jul 18, 2008 | Toyota Corolla Cars & Trucks
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
