Question about FUJIFILM A170 Digital Camera
I formated my SD Card in my computer, then, I inserd the card into camera. After camera ON, on the screen shows PROTECTED CARD and I can't take picture. How to solve my problem in order to I can use my camera again. Thanks for sugestion.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • FUJIFILM Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Dec 29, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
My memory card is not working in my Nikon S4100 camera. It keeps giving me the message "this card cannot be read". I What can I do about this?
1) Make sure that the write protect slider on the edge of the SD card is not in the protected position.
2) Make sure that the SD card has been formatted in the camera; not on your computer. The format function is in your camera's menu functions.
3) Try a different SD card that has been formatted in your camera. That will tell you if you have a bad card.
Jan 09, 2016 | Nikon Cameras
Apacer sd card
Hi Eric Chen,
there could be a couple of reasons the sd card is write protected,
1) Write protection enabled
- If it's the standard size sd card there's a switch on the left hand side.
2) May need to be reformatted
- First backup anything on the sd card to another location (ie: a folder on the desktop)
Go into you computer/file manager (some times called my computer) select the drive letter of the sd card (may listed as removal disk)
right click -> format, check that the right size is specified then click format (double check correct drive)
Then copy the files back.
Also you maybe able to use your camera to format the sd card instead.
Mar 08, 2014 | Computers & Internet
Canon 60d card write protected
This error is more common then you think.Since you tried most things, I only ask you to do only one thing. AFTER you saved the pictures on the card, just do a basic format (low level) in the camera. Just using the menu of the camera. You don't have to believe me, but cards formatted in other EOS cameras, yes from the same brand, can cause problems. Let alone when the card is formatted in a computer. If one or more cards work fine after you formatted them, and only one won't work, please discard this one.
Let me know if this helps.
Success
Feb 27, 2014 | Canon Cameras
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
SD card
you can try some data recovery software. You can see
recover files from sd card
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use sd card recovery software to scan again the memory card and recover your files.
Jan 24, 2008 | JVC Everio GZ-MG130 Camcorder
Card will not format
memory card? and SD card? whatever the card hook your camera to a usb to computer and find it under "my computer"
look at all your drives you should have like c, d , e, f, g, h, select the last drive and see if it finds your card if so try formatting it through the computer, whatever you do dont select c or d to format. if problem persists buy a new SD. I find good deals on ebay or Walmart.
Dec 23, 2007 | Samsung S850 Digital Camera
Sd card
I can think of a few things that might be wrong:
- Is the card write protected? Some SD cards have a small white tab that you can move to one of two locations. This allows you to make the card write protected.
- Has the card been formated in the camera? I could not locate a manual for this camera, but most cameras have the ability to format the memory card.
Lastly, I don't think you'll be able to record video to the card. Most of these camcorders have an SD card only for still images.
Good luck.
Dec 09, 2007 | Nikai DV7000 Camcorder
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
FUJIFILM A170 Digital Camera Logo
37 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
