Question about Sprint PPC 6700 Bluetooth Headset Headset
Instruction manual for blue tooth
My instruction manual for my Sprint Bluetooth Freedom Pack #GKX2880X or #GKX288OX (not sure if it a n "0" or an "O") has been discarded. Now I can't connect my bluetooth to my Motorola i335. can you help please?
thanks
Marc
In order to pair the Sprint Freedom Pack #GKX2880X, the headset needs to be on. Then press and hold both the "+" and the "-" keys until the blue light remains lit. The passkey code requested by the handset is four zeros.
Posted on Nov 30, 2008
Icandy freedom 180 bluetooth headset pairing instructions
How to connect my icandy freedom headset to another phone
Feb 13, 2012 | Radio Communications
How can i get bluetooth on hp 530 notebook pc(KD088AA#ACJ)
Hi meenarawat48...
You can install blue tooth on any computer using a "Blue Tooth Dongle"...it is a small item that plugs into your usb port and makes your laptop blue tooth compatible.
Do a "google search" on Blue tooth dongle to find one on the net.
http://www.dealextreme.com/p/super-mini-bluetooth-2-0-adapter-dongle-vista-compatible-11866
Please take time to rate me
Jul 26, 2011 | HP Computers & Internet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I need to hook up my blue tooth to my cell phone but I don't have the instructions or any codes. The blue tooth is motorola and the # is syn234OA/H385 and my cell phone is a Motorola Nextel. Thank you!
Here is your manual =0) Hope that helps
http://www.motorola.com/support/v/index.jsp?vgnextoid=125b3081efa2f110VgnVCM1000008806b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
Mar 06, 2010 | Motorola Mobility Bluetooth Hands Free...
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola H371
Guys, try to put in the number 0 four times, and that should work. I did it on my bluetooth and it worked. Good Luck !!
Dec 12, 2007 | LG KU990 Viewty
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
Bluetooth
you need to get the device introduced to each other. Turn on the bluetooth on the computer. Check Control Panel, Programs(for Toshiba Blue Tooth) or Check device manger to make sure the blue tooth is not disabled. Check the manual that came with your phone. You will need to put them in find mode and they should find each other. Here is the Toshibe site and booth info: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=1209152&ct=RG&soid=1328782&BV_SessionID=@@@@0630805741.1171140917@@@@&BV_EngineID=ccciaddkedlmlgicgfkceghdgngdgmn.0 Good Luck, Tim
Feb 09, 2007 | Toshiba Portege M400 PPM40U01000E Tablet...
Sprint PPC 6700 Bluetooth Headset Headset Logo
1,023 people viewed this question
Top Sprint Radio Communications Experts
eradiostore
eradiostore
Are you a Sprint Radio Communication Expert? Answer questions, earn points and help others
