Hi, I have a NEC Model RSH2423 split system still in great condition. It stoped working by Remote Control and only workson the forced operation under the cover. I have checked the remote and replaced the batteries and know it works. Is this a problem that can be fixed
  • 958 Answers
SOURCE: LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Posted on Jun 24, 2008
rayname
  • 70 Answers
SOURCE: hi i have kelvinator ksr25f
If fresh batteries dont help check if sensors are clear try removing power then restart unit
Posted on Jan 05, 2009
  • 340 Answers
SOURCE: The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Posted on Jul 19, 2009
SOURCE: Broken remote model hg31as. can't find replacement. need to operate manually. How?
I have the same problem, i cant find any replacement for this remote, but you can turn it on lifting the filter plastic cover and looking for a switch at the right center of the console.
Posted on Nov 25, 2009
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
I have a 2003 Checy Malibu and the horn will not work when I hit the steering wheel.
System Description
The horn system consists of the following components:
HORN fuse
Horn relay
Horn slip ring
Horn switch
Horn assembly
Body Control Module (BCM)
System Operation
The vehicle horn system is activated under the following conditions:
The horn switch is depressed.
The body control module (BCM) commands the horns on. The BCM commands the horns on under any of the following conditions:
When the panic button is depressed on the remote control door lock transmitter. For further information refer to
Keyless Entry System Description and Operation .
When the keyless entry system is used to lock the vehicle, a horn chirp may sound to notify the driver that the vehicle has been locked. The notification feature may be enabled or disabled through personalization. For further information refer to Keyless Entry System Description and Operation .
May 18, 2016 | Cars & Trucks
Remote control for Armstrong minisplit
You may be able to get any make of remote universal remote control and program it to operate your systems.
Mar 01, 2010 | RCA Universal Remote Control
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
LG Spilt A/C
medev,
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Remote for an NEC PX-42XR3A......
hello,
i have brand new remote for this model from nec company.........and 2nd you can buy yourself from company call this number and let them know your model they ,ll send u remote number is this 800-836-0655 original company website is this www.necdisplay.com
have great day let me know if u get it
thanks
Jun 05, 2008 | NEC PlasmaSync PX-42XR3A 42 in. HDTV-Ready...
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 27, 2008 | NEC VT47 Multimedia Projector
Lg airconditoner remote contol n98
Open the front grill of the indoor unit. Check on right hand side for a forced operation switch. This switch is for selecting of either manual operation or remote or auto, select remote, then try. You can also press the reset button on the remote, under the cover with a pen. Hope this helps
Oct 09, 2007 | Network Computing Devices NC900 Network...
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
