SOURCE: general error Delete all print jobs and turn the
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
SOURCE: hi, i have epson stylus PHOTO 1410. now i have
I have epson photo 1410
when I start the printer on the print head is not moving and the bottons flashing red lights
SOURCE: My printer tx110 series has a general error it
If your printer jams frequently, you may be loading too much paper. This
can also occur if you’ve had jams in the past and have a piece of
debris still stuck in the printer.
Use a flashlight to examine the
entire mechanism to ensure no paper is still inside. This can also
happen if an internal gear is damaged. You will often notice one side
being fed faster than the other.
This could me the printer is physically
damaged and needs to be replaced or repaired. You may need a professional help and send it out for repair.
Let me know for any clarifications.
SOURCE: Delete all print jobs and
EPSON STYLUS PHOTO TX700W Turn the printer off and delete all print jobs. Open the scanner unit and remove any paper from inside the printer and turn the printer back on.
