Question about Linksys Wireless-G Broadband Router
I dont know why my linksys router is not working!The circle where the power is,is blinking and the the wlan is on! Can u help me?
    President:
  • 2,017 Answers
Just switch off and restart the router and check the configuration of router is correct or not.
Just try with putting admin it is default password or you can try to put password as password. If it is work then great otherwise you have to reset the setting .in router there is one small hole just insert any pin inside and press it all the light will flash that means it is reset to factory setting and all the setting which is saved is erase . now access the router with default ip 192.168.1.1 and do the setting according to the internet .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Dec 29, 2010
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
I had a power shutdown and after my Cisco E1000 router suddenly stopped working. All the lights just completly froze (not blinking) just froze and i dont know what to do. Any help would be greatly app
Try resetting the router to factory defaults. With power on the router, hold the reset button in for 15 seconds, it'll be reset to factory defaults.
Try this at least 5 times before giving up!
Hope this helps!
Aug 14, 2012 | Cisco Linksys E1000 WirelessN Broadband...
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
Hello, my linksys router is flashing wlan,internet lights/ no-one is on line. is this normal?
Yes,
The links remains active when you are not using it and it is not unusual for lights to blink. And dont forget that Microsoft does various updates over the net when you are NOT using the machines.
Dec 29, 2009 | Linksys Wireless-G WRT54G Router
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
WLAN light on WRT45G
Hi ,
it will continuously blink . this shows the siganl is transmitting from the access point. and this frequency of this light blinking will increase when some client computers are connected to your access point or router
Mar 31, 2009 | Linksys Wireless-G WRT54G Router
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address 192.168.1.1? If that is the case, then assign 192.168.1.2 to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
The WLAN light will normally blink if there is data passing through. Most often if the problem is that you need a reboot for the router to work again you will need to update the firmware of your router. You need to go to www.linksys.com then click on the top right search then look for your model number then select the option to WRT54G downloads. Search for your model and then download the firmware. After that on a computer wired to your router go to http://192.168.1.1 through Internet Explorer. Click on the administration tab then click Choose. Select the file that you downloaded then click on Upgrade. That should fix your problem.
Jul 21, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
14 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
