Don't know...watching it and it just went dead!
  • 29 Answers
My Samsung 62" LCD started shutting down after the first year. I learned that their are inferior resisters in may models which short out after time with normal use. Heat is comonly the reason for auto shut down. make sure your tv has plenty of ventalation and keep the vent holes or slots clear of dust or other obstructions.
Posted on Dec 29, 2010
Went 'swimming' in the dead sea... after having my battery changed.. with a rep dealer??.... but the salt water got in... perhaps he didnt replace the O rings....can I salvage my watch?...
your watch has only to be cleaned. don't lose hope on that. bring it to watch expert, explain what happened. and i'm sure it can be fix. i hope i had been helped you.
Sep 05, 2011 | Watches
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
Battery change Citizen Promaster Watch Model# C112.
mcdevito75 here, You should be able to get some help online at citizenwatchserv.com in the meantime you can try to press and hold in the MODE button, press and hold it in for a couple of seconds. Also< IO wouldn"t be surprised if the battery has to come out and installed again, same new battery just simply have it taken out and put back in, maybe some sort of re-set. Check out the website, don"t do anything till then.
Jul 18, 2010 | Citizen Watches
My watch went blank and there is beep that is on and can't turn it off?
It happened to me too! As far as I know the watch simply had a short circuit and went dead.
May 20, 2010 | Kenneth Cole Digital Chronograph KC1411...
Just went dead
Recheck ur power source?All ready have,than ur power supply board it dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 31, 2010 | Protron PLTV3250 32 in. LCD Television
My RCA projection tv died
Ur BD power inverter board is dead.One of ur Capacitor or rmore it dead.U know how to solders?Buy the parts and replace it.Or buy the whole board and replace it.
Sep 02, 2009 | RCA P46924 46" Rear Projection Television
Tv went dead while watching
Sounds like the Power Supply on the TV went bad.
Sep 24, 2008 | Videoseven LTV30C 29.6 in. LCD Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
