Question about Dell Dimension 8400 PC Desktop
Ma pc dell dimension 8400 no prende el boton de l power cambia de color verde y naranja
tom19511
  • 1601 Answers
SOURCE: Woes with Dell
If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
Disconect fan , see if it starts.
Posted on Jan 13, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
Jubert
  • 249 Answers
SOURCE: CD RESTORE DELL DIMENSION 1100
La mejor manera de hacer esto es reinstalar el sistema operativo entero del rasguño. No hay restablecimiento de la PC para este sistema ni pudo ser dañado muy probablemente ya si usted tenía uno. Para probar, presionar ALT+F11 cuando usted enciende la computadora en la insignia del dell. Si esto no trabaja, usted necesitará insertar el CD de la reinstalación de Windows en la impulsión y cambiar formato su sistema entero y comenzar del rasguño. Después eso. usted necesitará instalar los conductores y las utilidades para el sistema del dimensiono.
Posted on Mar 25, 2009
  • 86 Answers
SOURCE: dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm
Posted on Jun 03, 2009
plettdoctor
  • 121 Answers
SOURCE: dell dimension 8400 fan runs at high speed upon power on
Check if the capasitors on the motherboard are "swollen" which would mean the motheroard is KAPUT. Check if there is a modem in the PCI slots which often shorts the motherboard (when it has become faulty) ... remove the modem. Try booting again. If not succesfull make sure the POWER SUPPLY workls correctly by replacing it with another working one..... If no joy... there are still one or two other options. Let me know If you still have a problem and I will give you more options to check on
Posted on Jul 06, 2009
Superstar 3900 el led rx/tx cambia a naranja en ves de rojo
There can be several things for that. 1 a bad microphone.2. bad switching diode. or 3 bad rx/tx transistor.. if its staying orange. the #2 is probably the issues.
can you provide more detail, as will it RX.. at all.? will it work in PA mode if theres one? etc
Apr 21, 2013 | Superstar 3900
El tv no da ningun tipo de video ni de informacion solo que cambia de colores la pantalla en varias tonalidades azul,gris,roja y verde
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 12, 2013 | Insignia CBPFTQ8CBZK024 Main Board for...
Como puedo programar mi contro de dish, para poder cambiarle a otro canal, nose que le paso pero no puedo mirar ni el menu de dish y al querer cambiarle de canal se cambia a componente 1 , video 1, video...
Hola Popysateaga, mi nombre es Kim y formo parte del departamento Social Media con DISH. Se que a este punto quizas ya no necesita de nuestra ayuda pero me gustaria contestar su pregunta por si en un futuro llega a necesitar la informacion. Cuando el control no responde con la programacion de DISH pero cambia los canales de la TV significa que el control no esta bajo mode Satellite. Si nota, en la parte arriba del control tiene 4 botones transparentes/blancos usted sabe bajo que modo esta el control al tratar de cambiar canales y el boton de 'TV' se ilumina ya sea rojo o verde. Para poner el control en SAT Mode de nuevo solamente Oprima el boton de SAT localizado en la parte de arriba del control por 3 segundos. Si necesita mas asisencia se puede comunicar conmigo a kimberly.escobar@dish.com
Dec 26, 2012 | DISH Network IR Remote Control
Codigos de programacion para mi tv tecnomaster
mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
Mar 05, 2012 | DISH Network IR Remote Control
Jeep liberty 2004 se enciende una luz en el lado derecho del tablero de color naranja q es
Exactamente cual es la luz que ve en su tablero...
Comentenos para poder darle mayires detalles.
Nov 24, 2011 | 2004 Jeep Liberty
COMO PUEDO QUITAR EL MODO DEMOSTRACION DE UN SONY BRAVIA 32BX3000
Entras al menú .... ajustes.... inicio automático. Ahí empieza una configuración inicial del TV y encontraras una seleccion de Modo entre Tienda y domestico. Seleccionas domestio y listo.
Un saludo...
Nov 02, 2010 | Sony Televison & Video
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Dell Dimension 8400 PC Desktop Logo
146 people viewed this question
Alun Cox
