Question about Tefal Toaster Ovens
How should I do the self cleaning for TEFAL OV1000 ACTIVYS?
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Heater works but trips after a minute
Hello
If u have 2 kinds of trip circuits
1) regular over current trip then there maybe a problem withthe mcb itself, so try another location that does not use that trip or higher amps trip .
2) if u have an mcb with special trip that also makes sure there is not leakage to the ground of toaster , then some toasters get the leakage after some time .
Feb 17, 2015 | Tefal Toaster Ovens
Cannot find the manual for tefal model 572325
http://kitchen.manualsonline.com/manuals/mfg/tfal/5252.html?p=3
Sep 24, 2014 | Tefal OT8065002 Toaster Oven
Mi plancha modelo G1490 no calienta, no prenden los lod diodos wool silk y linen coton y max.
follow this steps and fix it. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electric cord , and check the thermostat and replace if necessary. If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Oct 27, 2013 | Tefal T-fal E9421364 Castiron Plancha...
The interior of my euro-pro kitchen rotisserie convection oven model TO241R needs major soot and grease cleaning. Is there a way to clean it on high temperature setting? If not, please recommend a...
Most toaster ovens don't have a self clean function, because they are not made of the same sturdy metal that full ovens are made of. Clorox Clean-Up works pretty well if you spray it on the grime and let it sit for 5-10 minutes before wiping it away. Let it sit longer for tougher dirt.
May 03, 2011 | Toaster Ovens
CAN YOU PLEASE FURNISH ME A COPY OF TYHE TEFAL OVEN MANUAL FOR MODEL 572325
You can download the manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/TEFAL/AVANTI-_E
Oct 24, 2010 | Tefal OT806000 Avante Elite 1600 Watts...
Need to activater self-clean
Every self-cleaning oven is different. It's best to consult the owner's manual for the correct procedure for your oven. But often the steps are:
  1. Set the Start time for the time you want the cleaning to begin.
  2. Set the Stop time to a time 2-3 hours after the start time.
  3. Close and latch the oven door.
  4. Set the selector switch and/or thermostat to "Clean."
Jan 09, 2009 | Farberware FAC900R Toaster Oven with...
Tefal Oven faulty LCD DISPLAY
Hi babypom,
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
Rdgs
alan
Feb 18, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Toaster Ovens Logo
109 people viewed this question
Top Tefal Toaster Ovens Experts
ray gallant
Tom Chichester
Shimon David
Shimon David
Are you a Tefal Toaster Oven Expert? Answer questions, earn points and help others
