Question about Sony DAV-DX315 Theater System
I have a DAV-DX315 unit, all functions of the unit are working except for the DVD/CD function. The door will not open and continues to read a C 31 00 error on the display. I have taken the unit apart and removed all DVD/CD's from the changer, unplug the unit to reset and done a "cold reset" and still having the same issue. I love this unit and hope I don't need to replace........PLEASE HELP!!!!
5 Suggested Answers
SOURCE: 5 DVD disc changer doesn't open
are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Posted on Nov 06, 2007
SOURCE: Sony DAV-HDX265 Surround Sound
weel i tried doing that but still the dvd does not come out
Posted on Sep 09, 2008
SOURCE: DAV-FX900W System: DAV HDX576WF is throwing an error "C 31 00" and no...
I had a problem similar problem with a dav LF1. I undid a couple of screws, poped the top of the CD/DVD drive so I could them pull the disk out by hand. I then prised the slot open a bit more with my fingers and the plastic eject arm poped up, it seems it was stuck. Works fine now.
Posted on Dec 18, 2010
SOURCE: I'm getting the message C
It means the cd tray is stuck with something in it. My case was my 2 yr old putting my old soldier of fortune cd along with Happy Feet together. I had to take the outside panel off then inside you will see a white plastic box with the top exposing the cd storage. Cafefully take that white box off held with 4 screws moving any wires that are on the side. After I did that I seen where the cd's were stuck. I had to use tweezers to grab them out. I then had a problem with the storage lining back up with the grabber thing. I had to help it a little until all the cd's were out. It then reset back to where it was supposed to be.
Hope this helps..
Posted on Apr 23, 2011
Protector push power - dvd home theater system
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 20, 2009 | Sony STR-DE875 Receiver
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Jan 02, 2009 | Sony DAV-DZ100 System
DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Aug 28, 2008 | Audio Players & Recorders
Got a code c-81 then dvd player won't do anything. Help
A bizarre coincidence but our Sony DVD player DAV C700 did exactly the same when the kids were watching a DVD. All other functions on the system are still working but the DVD player wll not eject or play - and the self diagnosis function C 81 remains illuminated on the display.
Aug 06, 2008 | Sony DAV-C900 System
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
Avic D2 Won't Complete Initialization
you can open up the unit if you are savey enough and clean the ribbon with an alcohol pad. it worked for me and ever since i did that the door hasnt frooze up on me.
Sep 27, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
DVD Function Not Working
Help me!
Dav sc5 problema:dvd player no pictures scart and rca out,but have sound(rca out)
Sep 17, 2007 | Sony DAV-SC5 System
Help I am locked out ! Sony DAV S 550
Hold down the eject button for about 10 seconds
Sep 02, 2007 | Fisher DVD-SL30 DVD Player
Sony DAV-C700 dvd player not responding
take it to a authorised technician and get the lens reading circuit replaced it will work
Jun 12, 2006 | Sony DAV-C700 System
Sony DAV-DX315 Theater System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
