Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice maker My ice maker seems to be jammed . I used a hairdryer to melt some on the jam. It worked and the ice maker was working. It now seems to have the same problem. Do these units remove easily for cleaning and repair? Please help....it is very hot here in FL. Thanks in advance. my model ID # is GD5SHAXKQ00
  • Anonymous Jul 31, 2008
    Icemaker is constantly plugging up. Ice cubes seem to get jammed in the mechanism. What can be done to prevent this. We try to check it but forget sometimes and then you have no ice. This has been an ongoing problem with this refrigerator..
  • 61 Answers
This isnt uncomon whith sertan water conditions . try installing a water fiter ahead of the fridge ' also you can get a food grade silicone and after using your hair drier spray the ice maker ice serface and alow the product time to dry before restarting machine . food grade arisol is flamable so do not dry it with hare drier , it drys fast enough . you can get it a apliance or refrigeration parts wholesaler.
Posted on Oct 06, 2008
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
Ice maker all of a sudden stopped working.
Remove the ice bucket and look for ice hung in the fingers. Use a hair dryer to melt a jammed ice cube. Keep at it till the fingers move free and advance to the next harvest cycle. If the ice mold is empty replace the water valve. If the ice mold is full replace the ice maker.
Aug 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
Ice maker has worked great now all of a sudden has stopped completely Model HSS25IFMD
The ice maker maybe jammed with ice. Or pull the plug for a day or two to melt the ice then plug it back in. Good luck.
Jun 28, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice maker jammed how do I remove it.
What I do is use a hair dryer to melt the ice. Keep at it till the ice maker goes around and resets for the next harvest. Ice cubes hang up from time to time. I wrote an article on it
Help my Frigidaire Gallery ice maker Jammed!!
Mar 30, 2011 | Refrigerators
I have a Whirlpool French Door Refrigerator Model #G17FVCXWY and the ice maker jams up about once a month (ice doesn't completely dump into the door bin, water refills into the ice maker, then refreezes to...
HI, we have the same problem with ours from time to time. It is a engineering flaw, bad design, the ice cubes are kept in the refrigerator section, which is about 38-40 degrees. So the ice cubes melt, the only way to keep it clear is to use ice cubes every day and not let then thaw and freeze.
Mar 11, 2011 | Whirlpool Refrigerators
Our ice maker suddenly stopped working....help!
Well I would check for a hung up or jammed ice cube. I would use a hairdryer to get the ice maker going. If that was ok I would look in the ice maker for ice that ain't been harvested. That would tell me something is wrong with the ice maker. If the ice maker was empty and no ice was present in it , I would say the water valve was whack.
Here is a few notes and a standard im manual
Dec 24, 2009 | Kenmore Refrigerators
Ice jam in haier freeze
No you can use a hairdryer to melt it.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Dec 12, 2009 | Microwave Ovens
Ice maker stopped making ice. I had to melt ice
Jim, you will need to replace the heating element and most likely once this has been replaced, your ice maker should work properly unless the ice broke another part on your ice maker.
I would start with the heating element first.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct part out to you asap!
We look forward to getting your ice maker working properly again soon!
Thanks, Ella
Nov 09, 2009 | GE Profile Arctica Stainless Steel Top...
Ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Jan 11, 2008 | Freezers
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
112 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
