Question about Kenmore 34722 Grab-N-Go Upright Vacuum
My vacuume will come on, but the brush will not spin and the belt will not spin
  • 694 Answers
The belt may be worn and loose,causing it to slip on the motor shaft. If this is the case, you'll need to replace it. I generally recommend it be taken to a shop to ensure proper tension and correct reassembly.
Posted on Dec 29, 2010
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
Tip
Vacuum Brush Bar Not Spinning
" My vacuum brush is not spinning". OR
" My vacuum brush is spinning but not picking up".
" My dirt sensor doesn't work, continually blinks".
These three things are very common in vacuum cleaners and they are nothing serious. There is a rubber belt that drives the Brush Bar.You simply need to replace the belt.
* If the Brush Bar is not spinning, then you know that the belt is broken.
* If the Brush Bar is spinning but not picking up anything, then the belt is stretched to the point where it is now spinning on the Brush Bar. When this is the case, you may smell the belt burning and you may even see a little smoke.
* And, if the you have a dirt sensor on you vacuum and it continually blinks, this is due to a bad belt as well.
Whatever the case, the belt must be replaced. Belts are very easy to replace. In most vacuums, you turn the vacuum over and pop off the bottom to access the belt. In some other vacuums, there will be a little door/cover that pops off on the top side of the vacuum; allowing access that way.
You can pick a belt up at your large department stores or Do-It-Yourself Centers. These stores usually only carry specific brands, depending on each store you search. You may want to call around first. The belts are very reasonably priced for the most part.
Or, if you would rather shop on line, here is a link to belts. Just look up the Make and Model # of your vacuum and order.
govacuum.com/Categories/173-Belts.aspx
Good Luck!
If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Vacuum, Hose, Canister, Belt, Brush, Beater Bar, Smoke, No Suction, Not Picking Up & Spinning
on Oct 07, 2010 | Vacuums
The vacuum was working fine then suddenly the main brissels that spin to collect the dirt stopped spinning, the vacuum still has suction but barely picks anything up because the brissels are not spinning
Best thing to do is remove the spinning brush and clean all debris from the brush and most importantly from the ends of the brush. The ends of the brush usually have two holders (square?) that hold the brush in place on the vacuum. The brush is supposed to spin in these holders. If it does not, provided the belt is okay, the location where the brush contacts these holders need to be cleaned and lubricated with some WD40 or some 3 In 1 oil. Be sure the belt is in proper running condition as well.
Sep 05, 2010 | Bissell Cleanview Helix Vacuum
I have the bissell power force bagged upright vacuum and the brush is not turning, I have replaced the belt but the brush will not move but the metal piece that is hooked to the motor that spins the belt...
sounds like your brush roll is seized. Remove the brush roll (see picture) and make both of the end caps spin freely. If not, replace it and you should be set.
*An example of a brush roll*
Make sure that the brush roll spins freely.
Hope that helps.
Chris
Jun 09, 2010 | Bissell 3522 PowerForce Bagged Upright...
Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Apr 07, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brushes not spinning
Sounds like the belt has been stretched. Check the belt and see if the tension is ok. You should be able to view the belt after removing the sole plate. If the belt is loose you need to replace it.
Sep 09, 2009 | Bissell 3920 Bagless Upright Vacuum
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Kenmore 34722 Grab-N-Go Upright Vacuum Logo
78 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
