Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
We lose the internet entirely once we hookup through the router. Everything is fine before when we have the computer plugged directly into the modem
When i hookup my netgear wgr614 iget on connectivity. If i run modem direct to computer connect fine how to fix was working fine till last night
It seems that router need to reconfigure and once you reconfigure router i am sure you would be able to resolved issue.
Please follow steps to reconfigure router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Thanks for using Fixya
May 13, 2010 | NetGear WGR614 Wireless Router
Cant connect to internet through router
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 17, 2009 | Linksys Wireless-G WRT54G Router
ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Jan 26, 2009 | Arris Touchstone 450a (CM450) Modem
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Wrt54g V8 Suddenly stopped working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | Linksys Wireless-G WRT54G Router
Intermittent connectivity
Check to see if you are losing the DSL or Internet light on the modem when you lose your onnection. If so, then check with your IP provider, that may be the problem.
Apr 11, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Cnet broadband cnig-914
Can you log into the Hub at the IP http://192.168.1.1/ when it is connected to the computer and the internet connection? Perhaps it is just a configuration issue. http://www.cnetusa.com/support/manuals/CNIG-914D.pdf is the link to the manual to setup your router. Without further information about your network and its configuration I can't give more specific information. If you will please post any specifics about your configuration I can hopefully assist further. Please tell me how many computers there are, how many are directly connected to the router and how many are wirelessly trying to connect. Another suggestion is check your boot up order. Often times you have to unplug everything, then plug in the internet router, give it time to full boot up and have all lights on, then plug in the additional router (in this case I am assuming that it would be the CNet Cnig914), again allowing all the lights to come on, then plug in or turn on any pc that is connected directly to the router, followed by any computer that is wireless. This allows each system to be assigned the IP address and recognize the previous equipment. Once it gets an IP and everything is working you shouldn't have to repeat this process.
Nov 09, 2006 | D-Link DI-704P Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
194 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
