Question about Kenmore 63942 Dryer
Why does my kenmore dryer not heat up - Kenmore 63942 Dryer
  • 312 Answers
Why does my Kenmore dryer not heat up.
There are several causes, but the most common one is the heating element. Before we diagnose that lets get down to the rock bottom of basics. An electric dryer runs on 240 volts, like a AC system. So
240 volt systems use two circuit breakers. The heating element in the dryer works on 240 volts. The motor and all the other control parts work on 120 Volts. Just like the other electrical items in your house. So the first thing to do is Check the circuit breaker. A circuit breaker for a dryer has two switches linked together with a cross bar. (or it has two large fuses in which one could be blown) It is possible for 1 of the two switches to be tripped.
Locate the breaker for the dryer. Switch it completely off. Wait 20 seconds and turn it back on. If it won't go on, there is an electrical short in the dryer wiring.
Now we are going to check the heating element. But first, REMOVE ALL OF THE CLOTHES IN THE DRYER. Now turn it on and see if there IS heat when it is empty. If there is IS heat. Then the problem is a clogged, or pinched-shut vent hose in the back. In this case, the moisture in the clothes has no place to go, so it stays in the cloths and they stay wet. If this is the case, pull the machine out from the wall about 8 inches. look down at the hose from the back and make sure it is not crushed. Now see how it dries with the clothes in it.
Let's say it is still not hot. Now we are normally looking at a special white colored fuse that is
mounted inside in the rear. Or a blown heating element that is mounted in the same area.
This repair at this point would normally require a professional technician. BUT if you want to do it, let me know and I will advise you of the steps. Hope this helps,
Best, Mark
Posted on Dec 29, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Kenmore Dryer 300 Series No heat , I check continuity to all parts , it ok , but still no heat on dryer What's wrong?
What is the model number?
Exactly which parts did you check?
Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Oct 17, 2012 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore 70's dryer, not heating,
Maybe timer, try a different heat cycle.
Feb 06, 2010 | Kenmore Dryers
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore D433ele will not turn off...will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 31, 2009 | Kenmore 400 6942 Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
