Question about Brother Dcp395cn InkJet Printer
Brand new printer photos look bland and"unsharp"very dull color checked color shades but not using brother paper does this matter?
    President:
  • 2,022 Answers
Make sure the cartridges are proper and there is no dust on nozzle just clean with tissue paper and also use brother photo quality paper that is special type paper use that.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 29, 2010
Printing black or color pages very good. but printing color prints color washed out
Check that the printer preferences selection is consistent with quality required for Photo print and the paper you are using. Check under printer properties / preferences.
May 06, 2014 | Brother MFC Office Equipment & Supplies
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
I am printing exterior photos of a buildiing on regular paper for test only. The color is printing out with a green tinge. What is happening?
Not using genuine HP cartridges could be one reason. Low ink cartridges could cause not enough ink to be used to make a certain shade of gray or black and thus causing the green tinge. Also if you are selecting photo quality printing then you need to use photo paper. The printer drivers tell the printer different commands depending on what kind of paper you tell it you are using. Good luck!
Mar 09, 2011 | HP Deskjet 3745 Inkjet Color Printer
Compatibles wont work
Try this:
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
  1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
  2. Verify that the correct paper type is selected in the Paper Type setting.
  3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
Dull color
I would say phone or email Kodak as you may have a faulty printhead. If Kodak sayes you have a bad head they will airmail you one overnight and throw in free black and color ink tanks all free of charge.
I have read that some how in making the printhead a run got too hot in process and thus a bad printhead.
Hope this helps
Dec 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dull pictures ,new ink ,deep cleaning done ,ink heads cleaned
Are you using photo paper to print your photos? If you print photos using regular paper, the ink will spread out in the paper fibers of non photo paper and make the photos appear dull. I would try using paper made to print photos and see if that helps
Nov 07, 2008 | Office Equipment & Supplies
Brother 350c
First printing a photo takes lots of ink , it depends on the color of the photo , cyan is blue which maybe consumed more in the printing or there changes that the ink may have dried in the cart hence your getting this error ,remove cart take damp paper towel and hold the paper on the place where ink comes out gently for 20 second ,make it does not touch copper contact it may damage the cart ,make sure you check the place where ink with dry paper its usually bottom of the cart and repeat the above step with dry paper towel and try to print if you get the same error then you need to replace the cart or you can contact brother support and get cart replaced , once cart is used you need print once in week to keep cart from drying, you can use any photo paper which is compatible with printer .
Good luck....
Good luck....
Aug 24, 2008 | Brother Office Equipment & Supplies
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
Brother Dcp395cn InkJet Printer Logo
44 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
