Question about Photography
I have been given an old Manfrotto professional tripod model #058 that needs some serious attention. the colour of the legs looks like gun blue but it is very scratched and the only information regarding the type and model is what i've stated. many of what i think are the quick release levers are broken the rubber feet are missing and the leg locking nobs that tighten down are missing. the main crank that raises the "mast" has some worn down teeth and the housing that covers that crank is loose and does not seem to want to tighten. is there a good supplier for these parts that you know of. thanks for your time
    Scholar:
  • 175 Answers
2 Suggested Answers
  • 175 Answers
SOURCE: I have a Manfrotto 058 tripod. One leg wont hold
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Posted on Nov 04, 2010
Is there a Carbon fibre small compact with splitter
Carolyn
-If you are looking for a compact light weight (CF) tripod for video...., that is going to be...., stable & durable (for use with a smaller video camera or a DSLR) & with a mid-level spreader...., I have some bad news for you. They do not exist!!!!!
-You can get a number of tripods that meet some of these requirements..., but not all!!!
-No fear....., it is still possible to get a tripod that is small, light, repairable and with a higher weight capacity and better durability than either of the Manfrotto tripods you mentioned..., but they will not use a mid-level spreader!!!
-Questions for you...., the manfrotto #055CXB has a column that terminates with a flat plate & a 3/8-16" thread. The Manfrotto # MTV502AM tripod has a 75mm bowl mount. Do you use a video head with a flat base or with a 'bowl'?
-If your head has a flat base consider looking at CF tripods from brands such as Sirui (#N2204 or #N3204)..., great value tripod from China..., or products from Gitzo or Really Right Stuff...., (superior products...., and your grandkids will be using them..., but pricey)!!!!
-If your head uses a 75mm bowl mount get the Miller #1501 tripod...., stupidly strong and well supported.
-Bottom line..., with light to mid weight cameras, if you go with a good quality spreaderless tripod that uses 'rotary locks' vs 'quick release' locks...., the leg mechanisms are so superior that you will find that you will get less flex than most tripods with spreaders. They will also be smaller, lighter and allow you to shoot far closer to the ground!!!
Go t a shop that has a good selection of quality tripods and test for leg twist..., you will be converted!!! (note: to test this leg flex..., extend the legs & grab hold of (2) of the tubes near the top 'crown' and then try to move the legs to the left then right...., many will exibit significant flex at the joints!!!!
Jun 21, 2013 | Manfrotto Photography
I need instruction manual for manfrotto 058b tripod
There is a red slider under the main casting that will release the legs all together.
Apr 13, 2013 | Manfrotto 058b Triatt Camera Tripod Black
Trouble opening legs of my manfrotto tripod
Manfrotto have great warranties. If it is new, send it to Manfrotto to repair/replace the parts and make it whole again. If parts are worn it will be hard to tell you how to fix it without pictures, or know which model tripod you have.
Dec 14, 2012 | Photography
Leg stuck on Manfrotto 732CY tripod
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
www.bogentripodparts.com
bogen and manfrotto are the same company
Nov 07, 2012 | Manfrotto Bogen 732CY M-Y Carbon Fiber...
Broken leg clip on Manfrotto Modo 785B tripod the head is non-removable on this model and I don't want to have to replace whole tripod so is there somewhere I can buy a new leg clip or get it...
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
May 09, 2010 | Photography
Missing Tripod parts
Without knowing the brand of tripod i cannot help. There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Feb 12, 2010 | Photography
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
I need a lower leg clamp for my 190xb manfrotto tripod.
You can order the lower leg clamp as a part from http://bogentripodparts.com/parts/190XDB.htm
Follow the link and check for your part number.
Hope this helps,
Andrew
Oct 05, 2009 | Manfrotto 190XB Tripod
Photography Logo
180 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
