Question about Health & Beauty
PL SEND ME SERVICE MANUAL FOR X RAY MACHINE MULTIPHOS 10 PLUS
How do i record on a lg adr 620
[PDF]CD RECORDER / PLAYER OWNER'S MANUAL MODEL : ADR-620 - Elektroda www.elektroda.pl/rtvforum/download.php?id=354123 MODEL : ADR-620. Please read this manual carefully before operating your set. ... dealer or "LG Electronics U.K.Ltd." If the mains sockets in ..... POWER. PLAYBACK. SPEED. CD SYNC. ERASE. DUBBING. FINALIZE. ADR-620. 1. 10. 4. 5. 6. 7.
Mar 02, 2015 | LG Televison & Video
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
I need a singer sewing machine 7105 manual
i am also looking for manual for singer 7105.
if anyone has it, please send it to : olkawka@o2.pl
thx
Jan 19, 2012 | Singer Sewing Machines
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
How to service the bike at home
Best thing would be to obtain a service manual for the particular year and model of your motorcycle. The manual will show you the service intervals and tasks.
You can either obtain a service manual from the dealership or you might find something online, try Google.
Basic service usually means replacing fluids in all compartments (engine and transmission), clutch adjustment, clean or replace air cleaner, clean, gap or replace spark plugs, lube all parts that pivot, check tire pressures, visually inspect components like brake pads tires etc.
Hope that helps.
Jun 01, 2009 | 2005 TVS Victor GX
DVD repair
Buy a lens cleaner (about $7-10) at local electronics retailer. If does not help make sure dvd is not scratched of fingerprinted. Try multiple DVDs.
If all else fails, send in for service.
Mar 13, 2008 | Durabrand DUR7 Portable DVD Player
Fault code
I have look over the codes for your model and dont see an FH code if you post your email here i will send you the service manual
Jan 26, 2008 | LG WM1814CW Front Load Washer
Health & Beauty Logo
61 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
