Question about As Seen On TV Clapper Plus
The clapper says my light is on (yellow light indicated on the device) however the is in fact not on
What's clapper
Urban Dictionary: clapper
www.urbandictionary.com/define.php?term=clapper
Urban DictionaryA stripper who is able to make her behind shake so vigorously that the cheeks clap, or the behind that claps.
Clapper: For Your Car - Curbed LAla.curbed.com/archives/2011/01/parking.phpCurbedJan 24, 2011 - Shoppers who have lost track of their vehicle amid a maze of concrete ... What Really Happened at Rustic Canyon's Rumored N Ranch?"The Clapper" for your car - Honda-Techhonda-tech.com/audio-security.../%22-clapper%22-your-car-1068326/... Send a message via AIM to VAAJ. Default Re: "The Clapper" for your car (PHiZ) ... I like the idea... What is the US dollar for that? AU $99.00. Bbasso is offline ...Emoji Quiz Clapper board, Blue car, Oncoming car, Red car ...
Dec 08, 2015 | Cars & Trucks
I plugged a heating system into my clapper and now it is not working. The lights on the clapper don't go on when I clap. I think it glitches out but don't know how to fix it and now I'm really upset. What...
Clappers are only designed to manage less than 500 watts. Heaters are typically much more...greater than 900 watts. You likely burned it out and will need to send it in for replacement. good luck
Feb 01, 2015 | Miscellaneous
When LED lights are plugged in and the clapper is off - some of the lights still glow - not as bright as when on, but still appears as if power is seeping to them (just a little). Help - really wanted to...
There's nothing wrong with your Clapper. LED's have very low current draw - under that which is required by the Clapper to function. You can add a small nightlight to your lights which will up the draw for the Clapper to work properly.
Dec 18, 2010 | As Seen On TV Clapper Plus
My Clapper Plus works fine, except that when it is off, some current still leaks through. I have Christmas tree lights plugged into it. When the Clapper Plus is off, the lights are dim, but are still on.
You obviously have a faulty Clapper. They are supposed to work just like a switch...ON or OFF. If you are getting dim lights, it is bad. Take it back where you got it or call the company.
Thanks for using Fixya.
Wayne
Dec 11, 2010 | As Seen On TV Clapper Plus
My asus eee mini laptop with linux
Hi Clappers
You must go to setting>network>LAN & configure ip & dns then try
Harry
Jun 27, 2009 | ASUS Eee PC 900 Notebook
Clapper goes off every few minutes with no stimulus to do so
While in the Away setting, the clapper will turn on when it detects any noise over a specific threshold. After ten minutes of inactivity, it will turn off. This setting is meant as way turn on the lights as soon as you walk in the door or to startle might be intruders. If you slide the switch to Lo or Hi mode, the clapper will respond to your claps or any loud noises that sound similar. Hi is high sensitivity, for quieter rooms; Lo is low sensitivity, for louder areas.
Jan 27, 2009 | As Seen On TV Clapper Plus
Clapper plus
Sliding the switch down to the HOME (LO) position will put the Clapper Plus into the low sensitivity mode. This is helpful if there is a lot of external noise in the room. By placing the switch in the HOME (HI) position it will put the Clapper Plus into the high sensitivity mode for quiet clappers or if you are far away from the Clapper. In the AWAY mode appliances will turn on with the detection of any sound but will only stay on for 10 minutes.
Dec 06, 2008 | As Seen On TV Clapper Plus
Dash warning lights
These things seem to differ depending on where they were delivered and the fact that the bulb holders can be switched around easily doesn't help. Mine was delivered as follows: Red = Low oil pressure Yellow = Headlight on Green = Neutral... or maybe not Blue = high beam I've rewired my yellow to flash with the turn indicators 'seems more useful to me.,,
Nov 10, 2008 | 1981 Moto Morini 500 Turbo
As Seen On TV Clapper Plus Logo
69 people viewed this question
Top As Seen On TV Toys Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Toy Expert? Answer questions, earn points and help others
