How to replace rubber boot on a Whirlpool WFS1071BD gfront loading washing machine?
  • 1314 Answers
SOURCE: washing machine smells like burning rubber!
sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 20, 2008
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
  • 97 Answers
SOURCE: I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Posted on Jun 29, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
SOURCE: Burnt rubber smell after replacing motor coupling
what has happened is that the coupler has not been fully seated on the gearbox shaft, the motor shaft, or both. you should use a socket and hammer to firmly seat the plastic coupling on each shaft. If the coupling is not properly seated, the washer will work, you will get rotation, but there will be constant back pressure on the motor shaft, pushing it against the rear bearing race and the pump at the rear, the added friction causes heat buildup in the motor and sometimes overtemp switch operation. Just solved this tricky problem myself. another clue that the coupler isn't fully flush and seated is the last motor retention strap is very difficult to get on, due to the 1/8-1/4 inch extra length.
Posted on Apr 13, 2010
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Whirlpool front loader WFS1071BD I'm trying to source a manual for this machine? The rubber ring that sits between the front door and the inner core has come off.
i use manualslib as u can get and share manuals at ManualsLib Makes it easy to find manuals online failing that search in address bar with model and no as many sites have free manuals but beware the ones that charge...lol
Oct 24, 2015 | Washing Machines
Wfs1071bd
Hello, Here is the website for the users manual you need: Whirlpool Washer WFS1071BD manuals user manuals owners manuals how to...
May 21, 2014 | Washing Machines
Replace the baffle
There are several vids on YouTube that will show you how to do it. You can go general by typing this into search bar:
" front load washer rubber boot " or try this instead: " Whirlpool washer rubber boot " if you have a whirlpool machine for example.
Good luck. Let me know if those prove useless.
Jan 13, 2013 | Washing Machines
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the rubber boot on a whirlpool 9200
YOU HAVE TO TAKE OF THE FRONT SPRING AND TAKE OF THE BOOT FROM THE FRONT AND INSIDE THERE IS A CLAMP YOU MAKE LOOSE THAT CLAMP AND THE BOOT WILL COME OFF
Dec 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi there I have a whirlpool wfs1071bd sometimes when it is washing it will leak out the door I only put a few clothes in is there something wrong
Check the door seal where it meets the door..If there is even a small split it can leak....If damaged it should be replaced...Good luck....Nomess
May 13, 2010 | Washing Machines
Motor has load poping noise on front end load washer
If it is a front loader, reach just inside in the drum. Pull the rubber boot up and fell to see if something has gotten between the drum and the rubber boot, maybe a lighter.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is coming out of the front of the washer
The rubber boot that surrounds the door inside likely has a tear in the rubber. If the tear is small, you might be able to fix it with an application of weather strip cement. A large tear means replace the boot.
Aug 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jun 29, 2009 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
