Question about Acer P205H Widescreen LCD Monitor
Acer P205H I am using the monitor as external for my laptop gaming computer. This is the second monitor I have tried. I returned the first one because it developed a flicker of horizontal lines going from the top to bottom of the screen. I initially thought that it was because there are 2 computers side by side but when I moved my computer to the other room I still had the problem. Now this second monitor is developing the same problem. Another strange thing is happening. When I set up this monitor it automatically adjusted for the type of graphics used. IE Older computer games. The first monitor never did that. Now this one has stopped doing it and is starting to get the same flicker.
  • 68 Answers
SOURCE: Ripping horizontal lines on background
Your problem is not the drivers or hardware it is in your settings. Goto windows hardware settings for your monitor. Look down where it says refresh rate. Write that number down then go to the manufactures web site. Enter in your favorite search engine your monitor model and to to the manufactures site. Check to see what they recomend as your optimum and maximum refresh rates. Pay attention to the screen size also this plays a huge role in performance and out of sink refresh rates. Just out of coureosity are you overclocking your cpu or ram?
Posted on Sep 20, 2007
  • 117 Answers
SOURCE: display problem
this is a lcd panel problem not repairng this panel
its is coberage of warranty change lcd panel
    god luck
Posted on Oct 24, 2007
  • 116 Answers
SOURCE: Screen Flickering on Acer 3680-2682
Ok we must remember when we setup any device on our PC, one of the many non PnP devices is and LCD Monitor, your PC should always be shutdown before installing a new Monitor. If you did not do this you could have damaged the I/O port on your PC. Not a definite, but possible! When you plug up a monitor or any serial cable while the PC is still on, it is of a low voltage which can casue some issues for you! Sounds like this one is yours!
Posted on Nov 26, 2007
  • 180 Answers
SOURCE: Annoying discolouration across monitor
Does your monitor uses external Power Supply Unit ?
May be the video board need services.
Posted on Apr 19, 2008
  • 159 Answers
What do the power button lights do when there is a signal to the monitor and when it has a signal taken away from it ??
I believe your power boards have failed capacitors and need to be updated. Seems they used some crappy ones in some of these models.
I fix quite a few through ebay and that is a common problem, sorry to say.
Posted on Nov 08, 2008
Acer aspire 1 display not showing when external monitor hooked up. Starts and then says no signal
You may have to activate the external display port. On some laptops they use on of the Fn key combinations (look for the blue icons on the F1-F12 keys) Find one that looks like a monitor screen. Press and hold the Fn button and then press the blue icon key and see what happens. If something undesirable occurs, press the same key combination a second time to return to previous state.
Mar 18, 2015 | Acer Computers & Internet
Trying to hook up xbox 360 to computer monitor
Unless you monitor is HDMI capable I don't think it is possible without some sort of adapter.
Jan 19, 2014 | Acer P205H Widescreen LCD Monitor
Cannot view some webpages with acer p205h on ubuntu
This is unlikely to be a monitor issue, more likely a browser issue.
Please ensure you have the latest version of Ubuntu, Firefox and/or Google Chrome.
If this does not solve it, let us know which web pages you're having trouble with so we can take a look.
Jan 18, 2013 | Acer P205H 20 inch Monitor
My computer has reand black lines all over
To determine if the video card or the LCD screen is faulty, connect an external monitor to your laptop, power up the external monitor first the boot up your laptop. The video data will automatically divert to the external monitor. If the image on the external monitor is normal the the fault is in the LCD screen.
Either way, I suggest you return your laptop to the supplier because it should be still under warranty. If you try to fix it yourself you could void your warranty.
May 02, 2012 | Acer Aspire 1691WLMi PC Notebook
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
I have an Acer 5735 laptop. The external monitor port seems to have stopped working. It had worked fine. We have a second identical laptop and when I plug the monitor cable in it auto-detects the external...
try to update the video/graphics driver of your notebook. you can download the latest video/graphics driver from your computer manufacturer's web site then restart the computer
Jun 11, 2010 | Acer Aspire 5735 Notebook
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
Display coming for 2 sec and then it goes off
Does it work well with other computers?
If you are connecting to a laptop, try switching display modes (like you would do for a projector)
Sep 03, 2009 | Acer AL1916W 19" LCD Monitor
Acer P205H Widescreen LCD Monitor Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
