Question about Acer Aspire T310 PC Desktop
My monitor is always in power saving mode pls guide me to fix the problem
Monitor stays in "Power Save" mode
if u r reples this monitor pls. call me dear
tek a new monitor from me same model
Nov 27, 2012 | Dell ST2410 Monitor
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
My monitor is in power saving mode and screen wont come on
More likely to be in shutdown tahn power saving mode. You should try it with another PC first to make sure it is not video card problem or video cable problem.
If it is the monitor, then you should read my guide so you can decide if you want to DIY repair or not.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 21, 2010 | LG L1915S 19" LCD Monitor
Will not leave power save
This could be a computer problem more than a monitor problem. To check the monitor disconnect the video cable from the back of the monitor and see if you get any colored lines. If yes then the monitor is file. If even with the video cable disconnnect the monitor shows power save mode it a bad monitor. If you get the lines then you need to troubelshoot the computer. Try powering off the computer and then power it on and tap F8 as the computer restarts. If you get any display it should be a screen with the options safe mode etc. Select safe mode and start the computer up and once at the desktop restart, Let me know if this helps.
Rate if useful.
Aug 11, 2009 | Dell 1704FP LCD Monitor
How do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
In power save mode
I just bought my first computer. After the tech set it up and left I used it to become familiar with Windows. Then I did not have the time to reuse it for about a month. All I get is the same "power save mode" message on monitor then it goes blank.
Can anyone provide an answer as to why this occurred and what I can do about it? It's a barnd new HP 6130 Pavilion desktop.
Why do we need these machines if you can't control them? Nothing in the limited problem guide for the PC even addresses power save mode. HELP!!!!!!!
Jan 03, 2008 | Dell E173FP 17" LCD Monitor
Acer Aspire T310 PC Desktop Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
