Question about Microwave Ovens
My new gaggia platinum vision will not prime. it says "prime water circuit" and makes several loud clicking sounds and then says "restart to solve the problem", but this doesnt solve the problem. please help???
We had the same problem on our machine, and it was fixed by backing the strength setting (the physical dial on the front of the machine) off from the "maximum" setting a small amount. Somehow this was creating too much back pressure, and the useless "will not prime" message appeared.
Posted on Feb 17, 2011
My microwave just made a loud sound. It still runs but doesn't heat up. Is it likely a fuse & if so what do I do?
fuses make very little sound when they blow so a loud sound in a microwave is an expensive sound
best take it in for a proper diagnosis and quote as many loud sound repairs cost more to fix than a new unit
Dec 05, 2016 | Microwave Ovens
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
Mar 23, 2014 | Samsung RF260BEAEWW
Microwave JE 1860 has been making a loud noise for several months. Today it quit. Nothing works. No light. Turntable does not turn. Nothing on the display ... not even the clock. The unit was purchased...
Unless your personally attatched to this oven I would recomend you start shopping for a new one. Take the cover off and look for any fuses inside the front door area or on the control board, If they are bad replace them if none there then get a new one as they are more expensive to repair than replace. Most likely your magnatron shorted out and took the circuit with it, but check your house fuse as well on that circuit to be safe. A magnatron runs around 90bucks part only.
Jul 01, 2011 | GE JE1860 Microwave Oven
My microwave is making a loud buzzing sound. Inside the microwave, on the upper right side, is a square area with holes in it. It sounds like the buzzing is coming from behind those holes. Also, after...
THe buzzing noise is most likely coming from the magneton. The magnetron is the main component of the unit (it generates the microwaves). Replaceing it can be very expensive. You may be better off getting a new oven. Prices for new microwave ovens have dropped significantly.
Jun 12, 2011 | Microwave Ovens
I've got a model: JES1036PWH02.....when I plugged the unit in the internal light came on, the screen showed all eights and then in a few seconds shows a "PF" and NONE of the buttons work? How...
The keypad controller is defective, behind it there is the microprocessor ic mounted on a board with several other parts. The whole keypad and circuit board must be replaced, and the cost just for the part will run more than a new microwave.
Feb 06, 2011 | GE Microwave Ovens
Everything works but "heating". Makes grinding
The loud buzzing sound with no heating, is symptom that the magnetron has failed in your oven. Magnetron replacement cost are almost as much as new oven, so it does not make financial sense to repair. Sorry.
Jan 21, 2011 | Panasonic Microwave Ovens
I have a model GE JVM1653BD 001 microwave. Sometimes when it runs it makes a loud growling sound. It appears to be heating normally though. Intermittantly makes this noise.
I have the same model ending in 003, and it has made this noise for most of its life of several years now. Every now and again it runs quietly.
My theory is the cooling fan (not the hood fan) is making noise. The problem began within the first year of operation, and up till now everything is in good working order otherwise. There is no odor of failing parts.
My installation book has no electrical circuit diagrams, and I came upon your question when searching the topic.
Oct 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Keurig makes loud noise and sounds as it refills
hIi would return this should be under warranty
Jan 22, 2010 | Microwave Ovens
LOUD SNAP SOUND THEN MICROWAVE WONT HEAT
my microwave oven is a model lg lmv1630bb is making a loud snapping soud
May 07, 2009 | Microwave Ovens
Microwave Ovens Logo
232 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
