Question about UltraLast ULDCCL Universal LiIon Digital Camera Battery Rapid Smart Charger Kit
My ultralast universal battery charger for cameras flashes a red light when i put my camera's battery. what does that mean? it didn't do it before.
My battery died and i lost my charger so i bought a universal charger and it says the battery is fully charged, but when i put it in my camera wont turn on at all, a little red light flashes when i hit the...
dear sir,
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest olympus service centre and it is going to be done free of cost,as your camera is under warranty .......
thank you...take care
thank you.....take care................
Oct 08, 2010 | Olympus Camedia C-350 Digital Camera
Charger light flashing on and off and not charging battery
Hi, once you put your battery to the charger and the red light is blinking its means yor battery is damage you need to buy new. if the red light is steady only it means your battery is OK.
good luck and thank you my friend
Jul 18, 2010 | Casio Exilim EX-Z77 Digital Camera
My digipower travel charger flashs red when the
For mulitply camera battery charger ,there are many special online shop for you to select on the internet.
May 17, 2010 | Digipower Travel Charger for Select...
Battery flashing when charging why?
If the red light is flashing after inserting a NP-20 battery in the Casio Lithium Charger BC11-L, it means that the battery will not take a charge. Normally when putting the batterry in the charger, the light will be a constant red. After charging is complete, the red light will go out. Battery is then fully charged and ready for use.
Mar 19, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Hello, I have a EX-Z8 Exilim Casio camera. The last time the battery ran out I put it in the charger as normal. However instead of having a constant red light, the red light has a continuous flashing. This...
If the charge lamp flashes red it means the battery is faulty or the battery is loaded in the charger incorrectly. Take the battery out and check if the contacts are dirty - wipe them with a dry cloth and try charging again. If the error continues, you have a faulty battery and need to buy a new one. I found a link for cheap replacement batteries at http://www.mymemory.co.uk/compatible-battery/Digital_Cameras/Casio/Casio+Exilim+EX-Z8?gb=1&prodid=12068
You may find it cheaper elsewhere, but these guys include delivery. Hope that helps.
Sep 10, 2008 | Cameras
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Is my camera broke?
sounds like your battery or charger might be defective. I have this camera an when the battery is to low it flashes the screen.
I still use the original charger that came with it to charge the batteries,been thru 4 of those. It seems if they set a while without being charged the go bad.
Nov 04, 2007 | Video Cameras
UltraLast ULDCCL Universal LiIon Digital Camera Battery Rapid Smart Charger Kit Logo
115 people viewed this question
Top UltraLast Cameras Experts
Steve
Are you an UltraLast Camera Expert? Answer questions, earn points and help others
