My iomega 320 (lphd320-u) (p/n 31747300r) gig extrenal hardisk seems to be ok when i was inserting it on different pc's.The problems is when im transfering files or data into the copying seems to be never ending.what will i do.it has a supply of 5v on its case,do i need to plug an adaptor to make it work?or it simply the usb that will provide the power source for the hard drive
SOURCE: Iomega 500 gb hard drive: large file transfers
The default format for the IOMega drive is FAT32. This format will work on all versions of Windows, as well as Mac OS9 and above. Unfortunately, FAT32 can't handle files larger than 4gigs. If you want to use larger files, you're going to have to remove all the files from your IOMega drive and use your computer to format it to NTFS (Windows 2000/XP/Vista) or HFS+ (Mac OS9/X).
Consult your owner's manual for specific details.
Posted on Nov 26, 2008
  • 10406 Answers
SOURCE: how do I transfer photos
Connect the IOMEGA device.
Open My Computer.
You should see an icon and a drive-letter for the device.
Double-click the icon to open the device.
Open My Pictures.
Use "drag-and-drop" to copy files/folders from My Pictures to the device.
Posted on Sep 22, 2010
  • 13433 Answers
SOURCE: I have an Iomega SuperSlim
No the movies should play even with 128MB of ram, that is not the problem. It seems like your missing a proper dvd viewing program and video decoder.
I'd suggest that you install FFDSHOW video decoder and VLC media player.
FFDSHOW is available for download here http://www.afterdawn.com/software/audio_video/codecs/ffdshow.cfm
Download and run the program, in the setup all you need to do is to click next until the setup finishes. and then close or click on finish, it is done and can be forgotten. it will work in background when movies are played to decode to video.
Now for vlc media player. http://www.videolan.org/vlc/
Download and install the program just like ffdshow. Start the program with a dvd in the drive, click file open disc or dvd. make sure the drive letter is correct (letter of the external drive) and click play. or OK or Open, I don't remember exactly what it reads.
The dvd should being playing.
Let me know how it works.
-ekse
Posted on Oct 07, 2010
  • 32 Answers
SOURCE: please help me i have
You are most likely removing the drive while the machine is still using it, corrupting the data. Try loading data onto the drive, and then depending on your version of windows, in the bottom right system tray, right click an icon that looks like a usb drive with a green checkmark on it. Select the option to safely remove or eject removable media. Follow the on screen prompts until the computer says it is now safe to remove the drive. Unplug the drive only when the computer says it is safe. If you are using a mac, then drag the white drive icon to the trash to safely remove it from the computer, then unplug the drive. If you have further problems after this, then the drive is broken and needs to be replaced or repaired
Posted on Feb 28, 2011
  • 27 Answers
SOURCE: Hello, I have a Samsung
A knocking sound means your harddrive has either a bad head or a bad sector. This would also explain your freezing up, because your computer is unable to pull data from the drive.
To ensure that all of your data is safe i would follow these steps.
1: Do not continue using the computer without backing up your data.
2: Create a folder on your desktop
3: Drag the data from the drive to your computer. ( if not possible you may need to see a specialist)
4: If the drive is under warranty contact the manufacturer, if not you may be able to return it to the store in which you purchased it.
** Just remember, the more you use it the more likely it will completely fail and your data will be lost.**
Posted on Mar 07, 2011
Hard drive not detected by my pc . power lite is up while connect to pc . pc is amd athalon and usb hard drive is iomega 160gb
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb ,one after one .
After UN install all the usbroot hub, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
Hope it will help you
Dec 31, 2010 | Iomega Silver Series 320GB 3.5 External -...
I tried connecting my iomega prestige hardisk to my ps3(I just bought) but it is showing no icon or any notification of my hardisk being connected.What should I do to view its contents on ps3? about my...
You need to format your drive as FAT32.
If you are using Windows Vista or 7, you will have to google search for a FAT23 formatting tool. So take your data off the drive. Format the drive, put your files back on the drive and your good to go.
*************CAUTION************
There is a 4GB per file size limitation with FAT32!
Dec 14, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
I have an iomega 250 gig external hd. went to plug it in one day and my pc said it couldn't read any of the files. i can still see thumbnails and view photos but can't transfer any data at all. please help...
i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
Dec 02, 2010 | Iomega 33089 250 GB Hard Drive
Iomega 320 external hard drive computer wont recognise
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
I backed up my apple mac osx onto a lacie 320 gig
If its a pc running a different operating system then it wont know what the files are.
Jan 21, 2010 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Iomega 320 portable drive connection problem
sounds like a defective drive. maybe it took a bump in shipping?
take it back right away.
Sep 10, 2009 | Iomega (33576) 320 GB USB 2.0 Hard Drive
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
REMOVE WRITE PROTECTION FROM EXTERNAL DRIVE
insert your memory stick or your external drive / go to My Computer / right click your drive / go to properties / under the Security tab, just check the Full Control under permission / click apply then ok
hope this helps
Nov 04, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Pls help
configure wireless network
Press Fn (Function key) at the lower left hand corner and F2 at the same time.
select Internet tab>>click on wireless networks.
select the wireless network that you have, and click connect.
this is where you need to know what kind of encryption you have on the wirelss network.
select encryption type. (WEP, WPA or other).
enter passkey for the network, and Press OK
Sep 12, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
