Question about Hunter (25417) Ceiling Fan
What is a watt governor and what does it look like?
  • 3,640 Answers
It is a small black box for the lights. if lights blink on and off, it is the watt governor causing this. just remove governor and wire lights direct. part # 98480-02. have a good day !!
Posted on Jan 02, 2011
  • 2 more comments
  • hemi_boy426 Mar 31, 2011
    Was easier to find and rewire than wiring the remote to the light itself!! Works just fine now! Thanks for the help!
  • brady_mcnew
    brady_mcnew Jan 21, 2012
    most excellent advice! my light started flashing this morning out of the blue, as soon as I recovered from my seizure, I removed the watt governor and it's good as new.
  • Patricia Bargas Lozano
    Patricia Bargas Lozano Nov 17, 2012
    where do we find the watt governor on the fixture?
  • Larry Haltom Jul 14, 2013
    Great advice. I removed the watt governor and the light no longer flashes. Thanks.
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
Governor not working
make sure oil level is correct and viscosity. check governor arm for binding if loose and floppy internal mechanical damage. If you have the electronic governor actuator on your model then need to check for battery voltage on it, if present actuator bad, if not control board
Sep 10, 2013 | Craftsman 5600 watt Generator
How to adjust a fuel governor for a 3750 watt coleman generator
With parts list in hand, look at reference #21 governor arm and reference 89/90 adjustment screw. This adjustment will increase decrease engine speed. I would use a meter with hz setting to set engine speed to achieve 60 cycles. Sixty cycles on the meter would indicate that the engine is turning 3600 rpm which is max. If all working correctly, voltage should be around 120v at 3600 rpm and 60 cycles. Good luck
Aug 02, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
We had the Hunter fan installed in April and have been very pleased with its performance. About a week ago whenever you turn on the fan light it flickers nonstop. Can you help me?
this is caused by the watt governor or the black box in fan to the lights. remove the watt governor and wire the lights directly. when removed, hook white wire to white wire, and black wire to red wire. black and red wires are always the hot wires. governor part number- 98480-02, have a good day !!
Jun 19, 2011 | Hunter (25417) Ceiling Fan
When turned on the lights blink & the fan rotates in sync with lights blinking. Checked codes the are the same, changed the code's & same thing happens
if problems with lights blinking. remove watt governor or ( black box ) then wire lights direct. this will get rid of problem. governor part # 98480-02, hope this helps!! watt governor is on inside for the lights, it is supposed to reduce wattage.
Mar 22, 2011 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Hunter 'lodge' ceiling fan w/light: all switches 'on' and light blinks???? what do I do to correct problem?
if problems with the light blinking, remove watt governor inside fan, for lights. and wire the lghts directly. this should fix problem. the watt governor is a small black box to reduce wattage on the lghts. just remove it and wire lights directly. have a good one !!
Dec 19, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a fairly new hunter ceiling fan/light. Often when we turn the light on it continuously blinks on and off. To remedy this problem we need to cycle the switch (sometimes many times). I am assuming...
on most of the hunter fans there is a watt governor in it. if problems with lights blinking, remove watt govrnor, then wire it direct without governor. governor part # 98480-02, have a good day !!
Dec 12, 2010 | Hunter (25417) Ceiling Fan
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Sep 19, 2010 | Hunter Fan/Light Wall Mount Control 27186
My generator starts and runs great for a while then suddenly the rpms will drop or will race very high causing extreme flucuations in the power level produced
Take a close look at the governor and its associated springs. There should not be any play in the governor arm, springs should be taught when engine is off.
The governor spool may also be binding, but much harder to check since it is internal to the engine.
Start the generator, and watch the governor arm. When RPMs drop, you should see the arm move in an effort to open the throttle. Conversely, when the engine races, you should see the arm move in the opposite direction to try and close the throttle. Small movements of the governor are normal with a steady load. If you don't see the governor trying to correct engine speed, you likely just identified the culprit.
Jun 02, 2010 | Briggs & Stratton Briggs Stratton 6200...
Need to reset manual governor on 10 hp briggs and stratton mod # 205412 type 0178-E1. took pan off the governor does not look bad or broke wasker under the governor looks good. I think someone moved the...
First loosen the pinch bolt and nut on the govener arm at the governor shaft. To set the governor make note of the governor arm to open the thottle wide open. Hold the governer arm to where the throttle is wide open then turn the governor shaft that is coming out of the engine block in the same direction until it stops then tighen the pinch bolt and nut on the governor arm to hold the arm in position on the governor shaft. Make sure when you start the engine you don't over rev it. Start it in low speed and move up slowly. You may need to reset the spring tension.
Dec 14, 2009 | Briggs & Stratton Power Products 5,550...
Hunter (25417) Ceiling Fan Logo
5,059 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
