Question about Thomson Washing Machines
My Thomson washing machine TX 728N is not working. I think there is no water connected to the machine as you turn it on. Normally once you select the function and turn on you can hear the water being disperse to the machine but not now. Anyway the function is still running like from wash to rinse to try. But no water out or in ? Do you think it can be fix ? Thanks.
SOURCE: GE washing machine water overflowing
sound like the same washing machine from hell that we have. three or four times it has overflowed from want we have been told the hose that runs from the drum to on/off pressure switch cloggeds with soap. we have tried different soap,hot water,cold,water you name it we've tried it. so now evey time we use it we have to clean it with a coat hanger by taking the front off the machine.
P.S. take the hose off top and bottom to clean it, all it takes two/three very small soap bubbles to clogged it
Posted on Dec 30, 2008
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
SOURCE: how to use thomson washing machine tx 708
solved.
Posted on Jan 28, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
I misplaced the manual of my Thomson TX829, please can you advise where I can obtain a new copy.
Posted on Dec 05, 2010
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
The cycle does not go
The typical problem is a bad water pump. Your washing machine would still do the agitation part, though. It would just stop when it came time to drain the tub. Replacing the water pump every so often is almost routine maintenance on old machines. It's inexpensive and fairly easy.
If it won't agitate, there's another possibility. You have a safety mechanism that keeps the washing machine from doing the spin cycle when the lid is open (you wouldn't want your kid reaching in there while the machine is spinning). I think most machines will agitate with the lid open, but some machines might not - while there is a slight safety risk, many people want to add bleach, laundry additives, etc, while the machine is agitating.
There should be a pin on the lid that goes into a hole and pushes the safety latch when the lid is closed. If you're missing that pin, you need to replace it (that would be a good problem, since the replacement pins are very cheap).
Once the machine fills up, push a screwdriver into the hole a little ways and see if the machine starts working.
Apr 30, 2011 | Thomson Washing Machines
Baumatic BK6EL washing machine will not fill with water, it only lets a cup full in, shuts the water off and starts washing. Any ideas? Thanks, Mandy
One of the most common problems encountered with washing machines that need repairs, including Baumatic machines, is no water coming into the machine or the soap not being taken from the soap dispenser box. There are two main reasons why this could happen, 1. because the water has been turned off inadvertently from somewhere, or 2. because the water inlet valve as become faulty or blocked.
If your appliance is not taking in water the first thing you need to know is if the problem is with the hot or cold supply, to find out you can put your appliance onto a white wash cycle and start the machine this should bring hot water into the machine and you will know within a few minutes if the hot water supply is working or not, and to find out if the cold supply is working or not select stop/reset and then select the drain or spin cycle and this will empty the machine of any water, now select the rinse cycle and this should bring cold water into the machine and you will know within a few minutes if the cold water supply is working or not, once you are sure of the results select stop/reset and then select drain or spin again to empty any water that may have entered the appliance.
At this stage you should know whether the hot or cold supply is at fault, the next thing you need to check is that the water as not been turned off inadvertently, check both the stop **** and the washing machine connector valve/s, to see if you can tell if it as been turned off or not, if you think it as, turn it back on and do the hot and cold cycle test above for the cycle that failed, if the water is still not coming into the appliance you know need to turn the water off from the washing machine inlet valve/s one at a time and slowly disconnect the the inlet pipe/s from the washing machine side and point the washing machine inlet pipe it into a bucket and then turn the water back on, you should be checking to see that the water is on and also that the water pressure is OK.
There is a good chance your appliance could be working OK now, but If the test above shows the water is on and the pressure is OK but the washing machine is still not taking in water, you will need to have t the water inlet valve and or the water pressure switch and water pressure chamber tested, the diagnosis procedure covered here will work for Baumatic washing machines that need repairs, it will also work for most other makes.hope this helps
Aug 11, 2010 | Washing Machines
How to use thomson washing machine tx 708
Jan 15, 2010 | Thomson Washing Machines
The drum of my tThomson Washing Machine is stuck as the frame has
hi..
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
You will need to call Fisher Paykel so they may direct you to a local technician. the water valve assembly will need to be replaced at this point.
Aug 24, 2009 | Thomson Washing Machines
My Thomson S46-55 washing machine spins BUT does
Check to see what is the story with motor and belt tht turn drum and extract water. If belt has stretched it needs to be replaced. Search Over 2 1 Million Appliance Parts
Sep 11, 2017 | Thomson Washing Machines
HE3 front-loading automatic washer
Sounds like the water valve is not turning off 100%. Replace the inlet water valve. (where the hoses connect onto the machine)
Aug 28, 2008 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Thomson Washing Machines Experts
highlander28
Level 1 Expert
Garth Jackson
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
