Question about Genica 1-Port 10/100Mbps Fast Ethernet USB 2.0 Network/Print Server - Share a USB Device Over Your Network (PRS301UEPB) Print Server
Will the PRS-301UE print server work with an HP DeskJet 5550 printer and computers with WindowsXP and Vista operating systems?
Trying to set up my hp deskjet 5550 printer to my computer without a cd.
this is not possible. without the CD, you cannot setup the printer.
The good news is that you can download and install the driver/software of your printer without the CD from the below link. Once the link opens, select your operating system (Win xp/vista/7) and proceed from the download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=71896&
I wish you good luck.
Sep 15, 2010 | HP DeskJet 5550 InkJet Printer
I have an hp deskjet 5550 printer which used to be connected to my previous computer. My current pc has Windows Vista and although the printer works it just prints in tiny faint text and won't use my new...
Sounds like the working cartridges are badly clogged. Is the new cartridge HP brand or an "internet special"? Try HP originals and see if the machine still works ( I imagine it will). If not, then yes the machine is probably and the end of its life.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
Cant install the 5550 on vista computer...looking for driver for it.
Found this on the Web. Just select your operating system and click. If you find this helpful, pls rate me. thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=71896&lc=en&cc=us&dlc=en&lang=en&cc=us
Good Luck
Feb 26, 2010 | HP DeskJet 5550 InkJet Printer
My HP 5550 Deskjet won't print mirror image
You'll need to go to the manufacturer's site and find Vista drivers for your HP. Going from Win 98 to Vista is a major jump. I had to convert from XP to Vista and I still had to go get Vista drivers.
Also, make sure you get 32 or 64 bit drivers for the system.
May 12, 2009 | HP DeskJet 5550 InkJet Printer
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Aug 11, 2008 | HP DeskJet 5550 InkJet Printer
HP deskjet 5550 sometimes prints and icon reads Toolbox not available because printdriver is not installed
thats easy! HP has a bad habit of screwing drivers up! List here what operating system you have, and the exact,with any letters behind the 5550, model number here and I'll get the drivers. I have almost every drivers for windows for that particular printer
Jun 13, 2007 | HP DeskJet 5550 InkJet Printer
Genica 1-Port 10/100Mbps Fast Ethernet USB 2.0 Network/Print Server - Share a USB Device Over Your Network (PRS301UEPB) Print Server Logo
231 people viewed this question
Top Genica Computers & Internet Experts
David Payne
David Payne
Are you a Genica Computer and Internet Expert? Answer questions, earn points and help others
