Question about Sony STR-DG800 Receiver
Damaged hdmi ports by pushing into to small of cabinet space.
  • 1,557 Answers
Awch very hard repair if there is at least 1 hdmi connection working i would use it and by a manual hdmi switch adapter box
Posted on Dec 29, 2010
Cosby 40 inch tv, when I push Direct TV remote to turn on the television a small box with HDMI 1 THEN DVD 1 comes up. No picture and screen says : no signal
HDMI 1 is the DVD. If you want the Sat. go to the ports on the TV, look for HDMI 1 and pull the DVD line off. Replace with the line to the Sat TV equipment. Move the DVD to another HDMI port of your choosing.
Jun 08, 2015 | Televison & Video
My Vizio VU37L HDMI ports not working. AV ports work. Heavy lightning storm last night, TV was off when I went to bed, on when I woke up.
If you send the board to us we may be able to fix it.
What you're looking for is having to replace the small SMD IC that the tracks from the HDMI ports lead to.
Sometimes that is all it takes, other times it needs more and just today I've had a case where we just couldn't do anything as the damage seem to have spread to the large processor.
(it wasn't on a Vizio board, it was on a Sanyo, but the concept is the same)
www.coppelltvrepair.com
May 22, 2014 | Vizio GV42L 42 in. LCD Television
How to reset Prontotec 7 Inch HD?
Hi
Do you mean reset the Tablet? These Tablets don't have mechanical HHD they are IC's.
If you want to reset the Tablet to factory settings use a small stiff wire such as a paper clip, eye end of a sewing needle. Push it into the small hole between the earphone & HDMI sockets on the side of the Tablet. Push the reset button to reset Tablet
May 20, 2014 | ProntoTec 7 Inch HD 1024x600 Capacitive...
How to install an hdmi port on a toshiba c855d with amd e1 1200
You will need an HDMI socket, surface mounted and the corresponding components to solder on to the mother board. Very much a major task!
Apr 06, 2014 | Toshiba Satellite Computers & Internet
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
My tv goes black and some times frezzes whats cuasing this problem only when im playing my xbox 360 with the hdmi hooked up is there and update cuz im about to break this tv thanks
a couple of things could be happening first Check to make sure that the cable is not being pushed or pulled at ether HDMI port
second The HDMI ports and plugs could be dirt try and blow dust out of the ports and the plugs andthen see if the problem purists
third If the HDMI cable is lower quality or it is old the HDMI cable could need to be replaced a good place to purchase HDMI cables is http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=HDMI+cable&x=0&y=0
Fourth The ports on the back of the TV or on the Xbox could be damaged this is however not likely
Mar 05, 2011 | Insignia 42" LCD Flat-Panel HDTV
HDMI port isn't working for multiple monitors
is the card your using able to put out 2 feeds?
Jun 01, 2010 | Gateway DX4300-03 Desktop PC
HDMI PORTS NOT WORKING
Try visually inspecting HDMI’s that are not working. Occasionally, pins on HDMI connectors are getting bent or pushed-in. If you can spot the damage, fix would be to replace HDMI connectors. If connector are not damaged, then main unit of the TV has to be replaced.
Jan 06, 2010 | Televison & Video
Do HDMI ports on the back of the tv go bad? if so, how do you fix them?
If you have more than one HDMI connection try the others first. If it is an intermittent connection try cleaning the connector out first with compressed air in the can and make sure it is dry before powering the set back up again. If the HDMI is not working and you have tried different HDMI sources the HDMI receiver board in the TV might be bad. The connectors usually don't fail unless there is allot of stress placed upon them by to short of a cable going to them.
Nov 11, 2009 | Televison & Video
Onkyo TX-SR605 hdmi output jack was damaged and needs replacing. A) Where can I get the part and how much for it? B) Does the replacement part require solder or is it a snap in type connection?
The hdmi output and inputs are on a modular circuit board that you only need a philips screwdriver to swap out. I need this board as well since I also have a damaged hdmi output jack but have not been able to locate the replacement board. If anyone knows where to look I would appreciate knowing.
Apr 25, 2008 | Audio Players & Recorders
Sony STR-DG800 Receiver Logo
59 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
