Question about Dayton Electric Heater
Dayton model 2E669B electric heater hangs on swival mount.thermostat wires get hot and melt . set it on temp say 70 and comes on and works but not at actual temp
SOURCE: Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
The location of the sensor needs to be higher but my yellow wire would only pull out a couple of inches.
Turn off power to unit and remove front panel. Two screws near top/sides. Top of panel pulls out (unplug wire connector to indicator lights) and lifts off bottom tangs. Now you will see a coil of yellow wire inside unit. Remove the wire tie and you'll have enough yellow wire to locate the sensor well above the heater.
Posted on Dec 31, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: does our heater have a reset switch
Turn power off at the emergency switch or breaker. You may want to test the safeties in the unit. Sometimes they pop and are not resettable and have to be replaced
Posted on Oct 21, 2008
  • 108 Answers
SOURCE: Dayton 2yu62 doesn't work at all
Need to check heating elements and replace if necessary. If your checks are complete that is the answer I think.I suggest reviewing your findings. The heating elements rarely go bad.
Posted on Oct 22, 2008
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
  • 8 Answers
SOURCE: dayton electric garage heater
need to check you fan wires, some have differant colors on the moter for the differant speeds, you may need to change the fan speed by unplugging one of the wires and replacing it with another. hopefully you still have the manuel , check with it first!!!
Posted on Jan 07, 2009
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Hi, I have a Dayton 3ug73 heater. The heater will not shut down after the initial heat requirement is met. I have the thermostat set on low but it continues to heat. I shut the power off to it to keep...
It sounds to me like your thermostat may be bad. I would check power incoming to t-stat then turn temp. setting up and down to see if it is switching on and off. If not then replace. If it does then I would check all wiring to gas valve and if power is shutting off to valve but burner continues then replace gas valve. Thank you.
Mar 07, 2011 | Dayton (3UG73) Electric Utility Heater
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Dec 28, 2010 | Dayton Electric Heater
I have a Dayton model 2e695 electric heater that will get warm but never hot, any suggestions on what might be wrong?
Ohm out the heaters sound like one heater has failed? There will be two wires going into the heater if you unplug it there and set a meter to ohms and place a lead on each terminal of the heater you see something from 5 to 15ohms. If it reads OL that heater is open and not working.
Dec 14, 2010 | Dayton Electric Heater
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
I need a temp setting switch for my 2 mounth old electric garage heater. Where can I buy one?
The thermostat must have cost 2 cents. I replaced it with one from electric baseboard, real nice piece. Dayton should do the same.
Feb 03, 2010 | Dayton Heating & Cooling
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Dayton G73 electric heater
I just got my G73.  It comes with a new note that says "below 50 degrees the fan will cycle randomly (and might seem like its not working correctly) but once it is above 50 it will cycle normally."  it uses that to let the element re-heat quickly to bring the room up to temp faster.
Feb 13, 2008 | Dayton G73 Utility Heater
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
Nov 24, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Dayton Electric Heater Logo
122 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
