Question about HP Laserjet M2727nf Multifunction Printer
It didnot start ,you hear it warm up but there is no light or dose not work
The problem is with the formatter board, it is a cold solder joint/connection. What you need to do is remove said board, unsolder the battery that is on the board...now hold on for this one, you have to put in in your oven @ 380 degrees for about 8 - 10 minutes face down on a cookie sheet on a piece of tin foil. Believe it or not it worked for me and i have also fixed several HP LJ2015's the same way. Good luck
Posted on Dec 31, 2010
Why dose me oil light come on my bike
The oil light tells you when it has no or low oil pressure. Most often this is simply when the engine is not running as it needs to be running to create oil pressure. The bike not starting is not related to this light. Not starting when it is warm is often an ignition (spark) issue so you need to look at when it last had a tuneup and new spark plug.
Apr 15, 2012 | 2011 Derbi Senda DRD 125 SM
My 1980 ford bronco wont start. replaced solenoid and starter and it dose the same thing. wont crank wen i disconnect and reconnect battery and i try to start it all it dose is it clicks and everything...
it sounds like the battery has a problem with it and needs replacing,as you try to start the truck it pulls all the voltage out of the battery(which is very little in the battery)causing the clicking sound you hear,make sure the battery cable connections are tight and clean,both the terminals and cable ends.it takes very little voltage to power up a radio or lights and they probably stop working shortly after they are turned on.
Apr 06, 2011 | 1989 Ford Bronco
My fridge dose not work . It's not cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | Magic Chef MCBR360S Stainless Steel...
The fridge gets cold but not cold enough and the freezer dose the same
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 26, 2011 | Frigidaire Refrigerators
Warning buzzer keeps coming on ,ice maker dose not work , top of freezer no freezing properly
Refrigerator
heatman101
Dec 30, 2010 | Refrigerators
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="http://mojaizba.com/convert-units-of-flow" title="Flow units converter page on mojaizba.com - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute cu.in/min, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
I hear knocking when motor runing
WHEN COLD THEN GOES AWAY WHEN WARM. THATS NORMAL FORGED PISTONS SLOP WHEN COLD.I HAVE 01 SILVERADO WITH 390,000 RUNS GREAT 21MPG 40TO50 PSI OIL PRESSURE KNOCKS WHEN COLD THEN GOES AWAY. NOT A PROBLEM. IF IT DOSE IT WHEN WARM AND LOW OIL PRESSURE WORN BEARINGS NOT GOOD.
Jan 26, 2010 | 2003 Chevrolet Silverado 1500
Ford focus abs light dose not light up at all . ( 99-1.6.petrol)
read your owner manual to see when the BAS light should be on during "prove out." Sometimes the prove out is after the engine starts.
Also, if the ABS ever fails, you always still have regular power brakes.
You should go on a gravel road and slam on the brakes to se if the anti'lock still functions. You will hear the BAS motor run and the pedal pulse. good luck
Jan 21, 2009 | 2000 Ford Focus
My motor will start up run but when it get warm it stulls
Is there any engine lights that come on? Usually a Mass Air Flow Sensor will show up in a code.... Also when was the last time you changed your Oxygen Sensor?
Jan 14, 2009 | 1993 Ford Thunderbird
HP Laserjet M2727nf Multifunction Printer Logo
Seeker5211
Seeker5211
