Question about GPS
Instructions for gps unit dual xgps251 - GPS
Where can i download the Instruction manual for cubot p6 smartphone?
Unfortunately it is tremendously common across all android phones not to supply a manual.
Apr 28, 2014 | CUBOT P6 3G IPS 5" Android Dual SIM Dual...
My gps doesnt turn on even conected to the car,
GPS systems are standard features in many new vehicle . A GPS system communicates with satellites to provide directions through unfamiliar locations. However, older vehicles don't come with GPS, and many drivers purchase aftermarket systems for their vehicles. Installing a GPS system in your vehicle can increase its value and help make traveling a much more enjoyable experience.
Instructions And Materials Needed Below.
  • Plastic putty knife,Flat and Phillips screwdriver set,Wrench set,GPS system
  1. Slip the edge of a plastic putty knife under the edge of the radio face and lift the plastic housing off. Most aftermarket GPS systems incorporate a radio or CD player to replace the old stereo.
  2. Loosen the bolts on the left and right side of the stereo and pull it gently out of the dashboard. Unplug the connections at the back of the stereo and unscrew the mounting bracket on each side.
  3. Connect the mounting bracket from the stereo to the sides of the GPS system. If you've purchased the correct GPS unit for the make and model of your vehicle, the bracket will attach with just a screwdriver.
  4. Plug the wires into the back of the GPS system and slide the unit back into the dashboard. The ports on the back of the unit will be color-coded to correspond with the proper wire plugs, so there is no confusion when connecting the unit.
  5. Secure the GPS unit by inserting the bolts back into the bracket and tightening them with the wrench. Replace the plastic cover over the face of the unit and press it down until the plastic holders click into place. Turn the vehicle on and follow the instructions on the screen to program your new GPS system.
Good Luck.
Dec 07, 2010 | Magellan Maestro 3225 Car GPS Receiver
Need operating instructions foa a Garmin Nuvi
All User Guides are available for all units at Garmin.com. Navigate to your unit, and then to the download section for that unit. You can also update your unit's internal software at the same site.
Feb 19, 2010 | Garmin Nuvi 205T Sat Nav GPS Receiver
I have purchased new htc touch dual with tom tom satnav but cannot get linked up to gps
The HTC Touch Dual does not have a GPS receiver. You can get an external GPS receiver that links to the phone via bluetooth
Oct 17, 2009 | HTC Touch Dual Slider Smartphone
Displayed low battery msg then shut off and won't work even with charger
Most likely the battery has died - not just as in out of charge, but has lost the ability to hold a charge at all. This happens to rechargable batteries, and the thing to do is to replace the battery with a new one.
Unfortunately the XNAV3550 has an "integrated" battery, meaning you'd have to open the case (and void your warrenty) to replace it yourself. If the unit is still under warranty, contact Dual for a replacement. If the warranty has expired, then you might (if you're comfortable doing so) open the unit and see if the battery is easily replaceable. Otherwise I'm afraid you're out of luck. :-(
Oct 06, 2009 | Dual Electronics XNAV3550 Car GPS Receiver
Dual XDVDN8190 Hearing problems through Bluetooth
talk closer to radio the mic is a tiny hole on front right
Aug 30, 2009 | Dual Electronics XDVDN8190 GPS Receiver
I have trouble setting up the internet on a sci68 phone that I got yesterday. I would like to get maps and gps. HELP the book that I got is very limited. Is there a site that gives instructions.
Jul 15, 2009 | Dual Electronics N99i Cellular Phone
I need instructions for GPSNV-U94T
No GPS connection each time i want to use the navigator. Even though i drive the whole city or nearer to where the access point is, it's just the same message.
Please ai need your support.
Jan 23, 2009 | Sony NV-U94T Car GPS Receiver
Dual NavAtlas XNAV3500P
I had the same problem, check the fuse, also if the fuse is blown check the piece that fits into the device, you may have lost the little part that stops the fuse from blowing, it looks like a small ring on the end, stops it from shorting.
Does anyone know where I can purchase a NavAtlas 3550 cigarette lighter charger? I have tried 2 Universal adapters and none work! HELP!!
Mar 16, 2008 | Dual NavAtlas XNAV3500p GPS Receiver
GPS Logo
97 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
