Question about Norelco Quadra 7865 XL Electric Shaver
The battery dies with three green lites still showing. How do I reset the battery memory to get a full charge, and the flashing red lite when low ?
  • Norelco Master
  • 1,623 Answers
This problem indicates that the battery is worn out and needs to be replaced. You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Dec 31, 2010
    New Friend:
Norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 7865xl replacement parts.
Posted on Sep 11, 2013
Red lite flashes when i plug it in
I can only guess that the batteries need replaced .
Sep 05, 2015 | Rascal Auto Go 550 Portable Power Scooter...
Why does my chair show a full charge yet after only a half a block it will show only red flashing lite indicating needing charge.
Your batteries are nearing replacement time. They are becoming incapable of holding a full charge.
Apr 28, 2015 | Pride Jazzy Select Elite
What does it mean if a ds lite red light doesnt show up when you are playing it? The green light is on and plays fine but then when battery gets low the green light goes off and stays off but the red light...
This is OK the Red LED Has just gone out... simply just keep an eye on time if you think that it might die soon plug it in... there is not much that you can do to fix it.
Nov 21, 2010 | Nintendo DS Lite Console
Why does my ds lite not power up
Does the battery light flash? If red: CHARGE! If doesn't charge, a new battery is needed If green: New battery is needed
Batteries lose their charge holding capabilities after being used for a long period of time. DS lite batteries have a price range from around 4-20 dollars depending on the web site/store and the quality, some can go longer without charging, others can be charged a higher number of times so you won't have to buy them all the time.
If the light doesn't flash: I am not sure. I think a new battery should fix that too
Oct 25, 2009 | Nintendo DS Lite Console
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Reset button won't work on dell axim x51v
to wlumbria... hey listenup... if ur connecting ur pocket pc to the cradle it is not only used for the flow of data bt it also charges ur pocket pc... bt the chargin is quite slow  it will keep on showing  the red lite as compare to an charger it will charge fast and the red lite will turn green... so wht i suggest charge it with a charger not with a cradel if stil it doesnt wrk try changing the battery...!!!
Aug 21, 2008 | Computers & Internet
Both upper and lower screens are blank
You may be mistaking it saying it is charging with saying it is low battery. Green = Battery is well charged, Red = getting low, Flashing Red = Very low, Orange = Charging.
If you are certain that it is saying it is charged, charge it anyway, it probably is uncharged but is confused about whether it is charged or not. Remember that this is a machine: it has no brain, and cannot think for itself. All machines are stupid, they can only think what you tell them to think, and you have to be careful or it trips over itself and breaks.
Jan 02, 2008 | Nintendo DS Lite Console
Ds lite
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
Nov 03, 2007 | Nintendo DS Lite Console
Norelco Quadra 7865 XL Electric Shaver Logo
192 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
