Question about GPS
I have a 2002 Pontiac Montana with a ps3125sh Polar remote starter. About 3 weeks ago my grandson broke the red wire going to the antena right where it plugs into the antena. I unplugged the antena, and soldiered the wire back together. None of the buttons will function. Before that, all the buttons would work..remote start, remote door locks. I have checked all the other connections. None of the lights flash anymore. I dug out the brain box, and I find that there is a red led flashing constantly inside the box. I do not have the manual for this unit and am unsucessful at getting one. Help!!!!
SOURCE: powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Posted on Jan 10, 2008
  • 174 Answers
SOURCE: Software Update - Non-working Garmin Lock
Check to see if "Recent Selections" contain any of your favorites. You can then rebuilt Favorites from the Recent Selections. If the Recent Selections contain any of your favorite just select it and then select Save.
Posted on Jan 18, 2008
SOURCE: TomTom 520 won't start
I was having the same problem! Until I discovered that there is no SD card inside TomTom 520, just a bit of black plastic! I replaced this with a real SD card and instantly TomTom came to life!
The map and sample music are installed on its internal memory: 64MB of Ram.
Maybe this is of some help.... It did the trick for me....
Posted on Apr 02, 2008
  • 13433 Answers
SOURCE: lowrance LMS 337
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
Posted on Jul 09, 2008
  • 52 Answers
SOURCE: TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Posted on Aug 19, 2008
Where is the starter relay locationed on 2002 pontiac montana
Starter Relay
Right side of engine compartment on the radiator support, inboard of the underhood accessory wiring junction block
Near the battery .
May 01, 2017 | Pontiac Cars & Trucks
Polar start car starter
Check for a live skinned wire or tape wire,the wire had only be twist and taped(red should be battery wire)
May 04, 2014 | Cars & Trucks
Need to know what wires go to what terminals of the starter of a 2003 pontiac montana minivan
Should be two wires. The large red goes on the large terminal, and the purple goes on the small terminal.
The other wires with large ends go on the post with the red wire from the battery. The purple wire comes from the starter relay.
Aug 05, 2013 | Cars & Trucks
Pontiac montana 2002 interior fuse block removal
If the other windows are working, it would not be a fuse issue. You will have to take the inner door panel off, and check if the wires are getting to the motor, and not broke.
Apr 28, 2012 | 2002 Pontiac Montana
2002 pontiac montana with an occational starting problem
Go to Autozone and they will check your cars trouble codes for free and tell you what part you will need to replace. They are usually right 99% of the time.The crankshaft position sensor located behind the harmonic balancer maybe be bad. There is another crankshaft position sensor located on the engine block above and to the right of the oil filter. Or it could be the power train control module located to the right of the air cleaner box. This information is for the V6 3.4 engine. Buy the repair manual for your Montana and go to the engine performance section. The manual costs about $26.00
Apr 02, 2010 | 2002 Pontiac Montana
Where is the starter on the 2000 montana
Fowwow the large red wire from the battery and it will lead you to it. It will be on the lower part of the engine near the flywheel.
Mar 27, 2010 | 2000 Pontiac Montana
The wires with the large loops go on the big terminal. The purple wire likely is the one with the smaller loop that goes on the right terminal (facing the solenoid). That is ith trigger wire from the ignition key.Do not permit the wires from either terminals to touch.
May 24, 2009 | 2000 Pontiac Montana
2002 Pontiac Montana won't start "sometimes"
check battery cables.i had a 81 oldsmobile it done the same thing. it would not start after it got hot.i start mess around with it i shook a battery cable.the positive cable had broke place in it when engine got hot the broke place expand causing a open in circuit so the starter would start.also check make sure your injectors not leaking .
May 19, 2009 | 2001 Pontiac Montana
Changing the starter solenoid on a 2000 Pontiac Montana
On your van the solenoid is attached to the starter. If you can get a solenoid separate (i don't know if you can) then you will need to take the starter off and remove the solenoid (2 screws holding it on) and the wires (on red and one black i believe) pay attention to which wire goes where because you don't want to reverse it on the new solenoid.
May 12, 2009 | 1999 Pontiac Montana
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
