Question about Dryers
How do i relight the pilot - Dryers
  • Dryers Master
  • 8,220 Answers
Open the trap door and hold down the lever with the red knob. Light the plot and hold it till it stays lit on it's own. Ain't been no pilot lights on dryers for many years. Today's dryers have a gas assembly consisting of a silicone carbide ignitor, a flame/ignitor sensor, and a pair of coils. When the drum temp drps below 105f the control klixon on the blower housing powers up the gas valve assembly. The sensor, ignitor and coils are all energized. The coils however wil not open the gas valve because the ignitor is drawing too much current. The sensor FEELS the heat from the ignitor and @1800f the bi-metal inside it opens and kills the power to the ignitor. The ignitor also is connected to one of them coils that has 3 wires and it becomes a thermocouple device at that point. If for some reason the gas does not ignite the ignitor cools and shuts off the gas flow. how do i relight the - themobilian_601.jpgthemobilian_599.jpgHthemobilian_2.jpeg
How to change them coils
Posted on Dec 29, 2010
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
2her is pilot light on remeha avantaplus boiler
? 7:54
Light pilot light
Many heaters have pilot flames can be relighted with a match or push button operation. Many employ safeguards to prevent unburnt fuel from accumulating in the space or allowing an unstable pilot flame from "proving".
Most appliances have instructions printed or embossed on or near the pilot, gas valve or protective cover. It is very important to closely follow these instructions for your safety and that of others in the area. If you are unable to locate the instructions or follow them and relight the pilot, you should contact the gas company for assistance. This can be in indication of an issue with fuel, thermocouple, gas valve, etc., and would require a service person to correct.
I have included a link to a video to light a gas heater - yours may be the same or similar:
How To Light The Pilot Light On Gas Heater
Feb 23, 2015 | Heating & Cooling
Maytag gas dryer not heating
First make sure you have gas, then open lower section of this dryer you shoul see screws you will see a place to relight the pilot , if you smell gas before doing anything then stop your repair, see if the pilot is lit then push the red button and hold it relight pilot hold this button for a few min's after it relights, if it dosent relight check power goign to gas valve near pilot . Gas units have very little problems you may have just lost gas pressure and need to relight it , let me no ! what you see and we wuill go from there
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Kitchenaid stove top (17 years old) pilot light is out. How can I relight it?
To relight it you need to pick up the top from the front and then relight the pilot that is in the center between the burners with a match or a lighter...
heatman101
Apr 23, 2011 | KitchenAid Microwave Ovens
Pilot light is out need to relight it but do not know where it is located
The pilot is located in the bottom of the stove, you will have to remove the bottom drawer, and you will see the pilot in the back, you can relight it there, if there is no bottom drawer you will have to remove the bottom cover inside the oven and this is the location where you can relight the pilot.
Jan 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
Lochinvar water heater model LTN040G. Can't move dial from "on" past "pilot" to "off" to relight. Seems like there must be something I need to do to make it move, but can't figure it out.
The valve should be able to be depressed at the pilot setting and as you slowly depress it you should get it to move past pilot to off. You do not however need to go to off. You can go back to pilot and relight it and go back to on.
If it will not relight and will not go back to off it sounds like the valve is damaged internally and will need to be replaced.
Aug 07, 2009 | Pool & Spa
Relighting the pilot for a rudd heating and air
I dont know of any manufactor that makes a stand alone pilot anymore. (pilot you have to lite). The pilot should lite itself when you turn on the heat.
Sep 24, 2008 | Heating & Cooling
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
