Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp light on front of tv
Last night the light came on but it was not yellow to me....:D
It was more of a amber color it was not blinking. So. in the owners manual it said turn the tv off for awile and let cool and clean the filter.
This morning I cleaned the filter and replaced it then turned the tv on.
THe light still comes on and it could not possibly be hot it was off all night.
When I put the filter back in I thought I heard some small fan come on, but not sure. By the way I was told some men are color blind...the light was not RED it was a much lighter colorr.
Good morning:
I replaced my bulb and had a similar problem. I had a repair person come out and they found that the actual jack the lamp plugs into came out of the bracket. It literally fell inside the TV. The repair person had to remove the back of the TV in order to retrieve the lamp jack. You could literally see the open hole with a flashlight. If you pull your bulb out you can see if the jack is in place.
ELMO
Posted on Jul 08, 2008
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Replaced lamp a month ago. tv turns on then shuts off with blinking amber color. i do not have the original remote. What does it mean when blinking amber light comes
don't know what model but with lamps being replace, a few things are important, 1 the right part for your set, 2 not touching with hand, 3 cleaning the area first good, free of dust.
Jan 12, 2011 | Televison & Video
I have a Sony 50" WEGA rear projection tv. Last night it made a popping sound and then the screen went black. I could still hear audio at that time. I turned the tv off and now there is a blinking red...
It sounds lamp in tv got broken as you heard pop sound of it, replace lamp in tv to fix the issue.
Blinking light would be Lamp light at tv front that shows lamp is dead.
Lamp replacement procedure is easy and mentioned in tv user manual.
Thanks.
Sep 13, 2010 | Televison & Video
Tv used to make a whining sound when we turned it on, we would turn it off and on a couple of times and then it would be fine. now the tv won't come on at all, it blinks a green light and then shuts down...
Well that humming sound is indeed the color wheel, you say you already replaced it.
The thing is that there are two types of color wheels one with a silver bearing and another one with a gold one, for example if your Tv uses a gold bearing colorwheel and you buy a silver one, it's not going to work, if you still have the orginal colorwheel which i think you did since you replaced it last night, just make sure what color the bearing is. Because the color wheel is the one causing the issues on your TV.
Jun 30, 2009 | Samsung HLN4365W 43" Rear Projection...
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
J.v.c. big screen tv 56-58 inch
my jvc big scrreen worked just fine last night and this am i turned it on and the color is greena and red with double vision can you help
May 25, 2008 | Televison & Video
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
