Question about ASUS Eee 4G Notebook
My EeepC keeps telling me that that it can't find touch pad device and therefore I can't move the mouse
tom19511
  • 1601 Answers
SOURCE: touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Posted on Nov 11, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Panasonic cf-29 Touch screen not working
May be a conection problem. I had a cf72 that the conection had come loose at the motherboard. If its not the conection it may be the scvreen itself.
Posted on Jun 10, 2008
  • 45 Answers
SOURCE: the mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Posted on Aug 21, 2009
geo_jonas
  • 555 Answers
SOURCE: Acer Aspire 6930 Touch pad not found
Please reinstall your Touch Pad Synaptics Pointing Device Driver then restart your machine.
Thanks
Posted on Aug 27, 2009
allanhunt
  • 135 Answers
SOURCE: have a problem with the mouse on my eeepc
Try to check the touch pad settings in the control panel under mouse or you may also update the driver for the touch pad in the ASUS support site: http://www.asus.com/product.aspx?P_ID=PGEqzGdfmtS5rjPk
Posted on Mar 28, 2010
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
Apr 01, 2012 | Dell Vostro 1014 Laptop Computer
My mouse pad cursor do move but it doest whant to enter if i tab on it
some touch pads have a setting that must be set to allow a tap to be interpreted as a click. Go to Start-->control panel-->mouse, and look for a setting that tells the touch pad to allow it to sense clicks on the touch pad instead of requiring a button to be pressed. If not, try updating your touch pad driver. Start, right click on computer, click on Manage, when computer management window opens, click on the device manager in the left pane. Find mice and other pointing devices in the middle pane, and click the small triangle to the left of it, to expand it. Find the one under there that stands for your touch pad, and right-click on it, and click "Update Driver software." make sure you are connected to the internet first, and let it connect to Windows Update to see if it can find a newer driver.
Jun 24, 2011 | Lenovo 3000 N200 PC Notebook
Sony vaio AR51E mouse cursor doers not move as touch pad not respoNding, EXTERNAL usb mouse works fine any ideas??
Go to Control Panel
SEE mouse icon... OPEN this
see if the touch pad is disabled
Try to go to the site Sony VAIO model specofic download latest driver for the touch pad
there are specific setting to enable the pad somehate it some love it but you can sort it out by looking at Control Panel /device manager etc
if USB mouse is working at least you can navigate to find issue
Jun 11, 2010 | Sony VAIO VGN-AR720E/B Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
My eeepc right click pad button isnt working. The left button is working fine & the right was too, up until about 10 minutes ago.
I am not sure how old you eeepc is, but the touch pads and it's buttons are a common issue. Try to buy a wireless mouse. it is much faster and easier and cheaper to fix. But if it is under warenty have it fixed. it just depends on your needs. A mouse will run you $20-$40 and the touch pad will cost you more $ or a month or so to have it fixed.
Sep 06, 2009 | ASUS Eee 4G Notebook
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
Apr 01, 2009 | Gateway Laptop Keyboard for MX6930,...
Whilst typing the cursor moves to another part of the document
If your laptop has the option too you can turn off touch pad through a switch above the touch pad.
If you can't find this, or you don't have one, simply go to the run command and type in devmgmt.msc, ok.
Once in the device manager go "Mice and Other Pointing Devices"
look for your touchpad, right click on it and select disable.
Please note, some laptops wont let you disable to the touchpad, mine wont, but mine has an on and off key.
ON/OFF Key
Touch Pad On
Touch Pad Off
This will keep the mouse from moving whole you type, but I suggest you get a regular mouse, especially if you have to disable the device with the Device manager.
Jan 05, 2009 | Computers & Internet
ASUS Eee 4G Notebook Logo
660 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
