Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
Write protected memory card..sd card
Cannot get anything to go to my memory card..trying to copy files from laptop to phone memory card but it is saying that it is write protected..
  • 8 more comments
  • Anonymous Jul 20, 2008
    I can only copy file from my micro SD memory card... but i can't write or modifi any of them
  • andrew_ans Aug 05, 2008
    I have SD card.i cant delete from my card and not copy from my computer to SD card.if i try, one warning note come that is 'The write-protected'. How i can remove this write-protection from my card and use without obstacle?
    Amal
  • ragefire456 Aug 16, 2008
    i get a write protection message whenever i am copying something in my sd card
  • amanswaich Aug 23, 2008
    how can remove write protection ???? i cant copy anything in my mini sd card ?
  • Anonymous Aug 25, 2008
    i tried to install files on my SD memory card and i also tried to formated it but it always that the disk is write protected how can i fix it pls. help me!
  • rawdon1 Oct 06, 2008
    DANE-ELEC 4GB USB DRIVE
  • cdplayerto Dec 18, 2008
    I have the same problem! I can copy the files that are on the USB key but I can't create files or folders. How to I unlock it? I don't see anything on the key that would allow me to unlock it?
  • Anonymous Jan 29, 2009
    I, too, have a Dane-Elec 4GB USB drive. It suddenly & magically became write protected. Can't figure out how to remove write protection.
  • deadlyjynx Apr 07, 2009
    My DaneElec 8GB USB Drive was working fine the last time i used it.. but now it's saying its `write protected`. None of my other key drives do this.. Where is the 'switch'?
  • Anonymous May 23, 2009
    OMG! I HAVE THE SAME PROBLEM!
There should be a little switch on your memory card reader, if it is facing down, your card is locked. Push it up and then you should be ready to go. :)
Posted on Sep 06, 2008
Do not transfer files from c disk
Posted on Sep 04, 2008
Nothing ......still same. where and how can remove password
Posted on Sep 03, 2008
Cant get my dance-elec working
Posted on Apr 02, 2009
    Problem Solver:
  • 5 Answers
Take it out of the phone and use a card reader. Also make sure there is not a password set on the memory card as this will activate once removed from the phone. goto your phone options and remove password to be on the safe side.
Posted on Jul 10, 2008
is write
protected and there is no switch on it ?
Posted on Oct 06, 2008
My deleted file is in the sd card.. can the phone memory or whatever storage it has in the phone can recognize the files in the phone memory? -- is the phone memory or any storage of phone can read and...
Usually the SD card is a secondary storage device ... and separate from the (internal) phone memory. To determine / test this, see if your phone still have (some) information when you remove the SD card from the phone... e.g. your telephone contact list, etc.
Yes, you can try to recover the "deleted" file on the SD card using a PC / laptop ... using a data recovery utility/tool (on your PC) to scan the storage space or "undelete" that deleted file..
If your phone can be attached to a PC (e.g. via USB), and if your PC recognizes the "storage" disk on your phone as an "external" disk, you may also be able to use a data recovery utility to scan the storage space or "undelete" that deleted file.
Nov 04, 2013 | Samsung GT S3850 Corby II
In my Nokia 5130c-2 mobile I've a 8GB Micro SD memory card. When I try to enter into Memory Card it tells Unknown File Format in Memory Card. Format Memory Card Yes/No? Every thing was going fine...
Put the SD card in a stand alone card reader, and copy the data off it to your computer. Next, format the SD card, and put it back in your phone.
May 06, 2011 | SanDisk 2GB microSD Memory Card
When iam copying any thing from my pc to my mobile It shows error copying file or folder make sure that the disk is not full and write protected and file is not in use..... but they all are wrong...
check the memory card if its working fine. the memory card might be corrupted thats why it aint accepting any files coming in from your PC at all. hope this helps
Feb 12, 2011 | Computers & Internet
How to remove write protected memory card
Dear the card adaptor which you are using on the side of adaptor there is a side lock please check it may be it is lock that's why u r not able to transfer data.
May 20, 2009 | Motorola Mobility L6 Cellular Phone
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB...
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
Nov 19, 2008 | SanDisk 2GB microSD Memory Card
My sd memory card does not work properly
your card contains fat file system. format your card with ntfs file system.
Nov 13, 2008 | Rio Forge Sport Digital Media Player
micro sd 1gb card write procted problem
Sep 13, 2008 | Nokia N95 Cellular Phone
hey that is because your nokia phone need to format to format any nokia phone
1-close your phone
2-put your memory card in it
3-press on the button that you answer any call from it with * with 3 whith the power button all of them togethier whe the phone is closed aND IT WILL START FORMATING
Jul 26, 2008 | Nokia 3110 Cellular Phone
Samsung micro sd memory card
THE CARD IS WRITE PROTECTED
OR THE FILES COPIED ARE WRITE PROTECTED.
SO REMOVE THE WRITE PROTECTION ITS LIKE A SMALL SWITCH WHICH SLIDES ON THE CARD .. ONLY CERTAIN CARDS HAVE IT .
NOW IF THIS DOESNT WORK
PUT THE CARD IN A PHONE AND SEE PROPERTIES OF THE DATA THERE , REMOVE WRITE PROTECTION .
Jun 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Turn off write protection on a sd micro card
If you are using it with the SD adaptor, the swith at the side marked lock is not to secure the micro sd card within the adaptor. This is the write protection. If you set this to the 'unlocked' position (up) then you should be able to write files onto it!
Apr 04, 2008 | Nokia 6288 Cellular Phone
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
2,433 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
Piyal Perera
Piyal Perera
woodzowl307
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
