Syncmaster 2243 bw samsung. Check signal cable message
  • 11,800 Answers
The monitor is fine, just that it doesn't receives any signal from the video card of the pc. You will have to test it: start by using another video card.
Posted on Dec 29, 2010
Why do I have no signal on the Samsung syncmaster 940 mw tv
Check your cable connection on both ends. Try to change the cable.
Oct 06, 2014 | Samsung SyncMaster 940MW 19" LCD Monitor
I have two monitors. One Samsung SyncMaster 2233 an one Samsung SyncMaster 2243. My problem is that the SyncMaster 2233 for some reason is totally black. I'm usually not terrible with these things, but my...
You're using dual monitors and one is black? If so-- when you switch the cables on the monitors.. the same monitor stays black? This sounds like bad monitor. If I understand you right.
Feb 10, 2011 | Computers & Internet
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computers & Internet
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
Samsung syncmaster 2032 BW
  1. Reboot the PC while the monitor is connected.
  2. Check the connector for bent pins.
  3. Return the unit and get another.
Hope that helps...
Geno
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
