Question about Whirlpool Washing Machines
Hi, My washer does not do the final spin.....Everything else seems to work except the final fast spin. Is there anything i can do?
  • Whirlpool Master
  • 8,220 Answers
Stop using so much soap? These newer washer must use a slight amount of HE soap. Any other thing will cause motor over amping, burn up sensors, and cause the control to work overtime trying to remedy the problem. F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
More Here
Posted on Dec 29, 2010
Loud noice in the spin cycle while going fast
What is the complete model number of your unit?
Dec 04, 2012 | Kenmore HE2 Plus Front Load Washer
My washer stops during the final spin cycle, it will drain the water but the clothes are still soaked....every time, we have to re-situate the clothes and manually give it one or tow good spins then it...
Hi from retired Englishman in SW France @ 14:15 Wed afternoon.
What make and model- front or top loader, please?
Does it seem to struggle and be intermittent frequently, particularly when spinning? Is it not running at true spin/fast speed?
Also how old/used- I'm trying to ascertain if it is the main motor's worn brushes or the belt slipping or something else!
Cheers,
John C
Feb 02, 2011 | Whirlpool Washing Machines
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
Frigidaire Galleria Front Load Washer.
Could be anything from lid switch to pc board to belt tensioner. Start with the cheapest and easier first with lid switch and belt tensioner.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Horrible noise during fast spin
nail washer to floor or strong glue it to the floor
Dec 26, 2008 | Danby DWM5500W Front Load Washer
Kenmore Washer 41729042992
Plug off the wall socket. Your motor brushes need to be cleaned or changed.
Jun 25, 2008 | Miele W1903A Front Load Washer
Washing Machines Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal De
