Question about Refrigerators
Maytag mfd2561heb double door frig making clicking sounds, gradually warming. I think the defrost heater may not be working. How to check defrost heater? Should I remove the back panel in the freezer drawer section? That's where the clicking sound is coming from, which I imagine is the fan hitting a build-up of ice.
    Sergeant:
  • 183 Answers
The defrost heater is one part that may be bad, but before you make it the culprit, test it first with an ohmmeter for continuity. If the heater tests okay, the defrost thermostat is bad and needs to be replaced.
Posted on Dec 29, 2010
Maytag P MFD2561HEB model the frig is not cold but the freezer is fine. How do we set the frig control?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Refrigerators
Frig Freezing Up/Frig side warming up Maytag MSD2454GRW
I think your voltage is fine I just believe the defrost timer is worn out and not cycling properly resulting in less defrost and higher refrigerator temperatures. Thanks, sea Breeze
Aug 26, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Side by side Maytag frig that is warm on top, not bottom
You can turn the thermostat off for now to let the ice thaw out, if a door was left open there might not be anything wrong, but if it freezes up again sounds like you might have a bad defrost heater or defrost limit. Hope this helps
Apr 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
My american style fridge/freezer is continually running but not keep cold. Have to empty the freezer side and the fridge is not cold either
It could be the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Nov 22, 2008 | Maytag Refrigerators
My Bosch upright fridge is not defrosting & has a wall of ice on the back. The fan does not appear to be working either. Is that the problem? - cant remember how often I see the fan working now!Thanks
I kind of doubt that the fan is the problem. On my refrigerator, when it goes on defrost, the fan shuts off. They don't want it blowing heated air on the milk. Yours might be different.
I don't know this particular frig, but evidently the defroster doesn't work. Perhaps the fan doesn't work also, or perhaps the fan would work if the defroster were fixed.
I think that when the defrost heater is turned on, then the fan is likewise turned off. The defrost thermostat, I think, is doing it's job, letting it cool again. But the timer is stuck. Or something???.
Aug 18, 2008 | Bosch Refrigerators
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Magtag french door with water and ice despenser door with auto defrost keeps freezing up.
You have a defrost system problem related to the timing device, heaters, or defrost thermostat. Coils for the freezer are inside the back wall and defrosting the surface does not get ice out of coils.
it will not get any better until you have it serviced. This is not normally a project for a do-it your selfer.
May 28, 2008 | Refrigerators
Maytag Frig. Model MSD2651HEQ not working
Your start relay for the compressor is probably the problem. If ordered, you will most likely receive the relay and overload protector. Replace them both.
Sep 27, 2007 | Refrigerators
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
May 31, 2007 | Hotpoint HTR15BBMRWW / HTR15BBMRAA /...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
