Question about Microsoft Windows Server Standard 2003 for PC
BSOD I was installing Windows XP SP1 on my PC.After the completion of copying in DOS stage the first restart took place to boot through the XP for setup.Then just after the system logon BSOD comes with a message   SESSION5_INITIALIZATION_FAILED Code 0x0000071. I do have Windows 98(Dual Boot) working properly.
  • Shaun Harris
    Shaun Harris May 11, 2010
    Have you added anything to your computer before you tried to install ?
  • 2,427 Answers
Your MEMORY (RAMS) are damaged if you have memory in multiple **** remove the ones in **** 1 and replace them
Posted on Jul 09, 2008
This looks like the codes from a Blue Screen Of Death (BSOD). If so you will need a system disk to boot from and get to a dos command prompt (black screen with white writing) and type the following command:
chkdsk /r
Check Disk Repair will run for well over an hour and you will see the percentage of completion going from high to low but that is normal. Let it run to completion and then reboot.
In Windows XP to get to the dos command prompt boot from the system disk and when the options come up select Repair. Select 1 for the Windows Operating System and when it asks for the Administrator Password just press enter.
In Windows Vista to get to the dos command prompt boot from the system disk and when the options screen open you could try a startup repair. If it fails look the dos command at the bottom of the Recovery Console.
Mar 23, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
How to remove this copy of windows did not pass genuine windows validation
First enter into BIOS setup by pressing key recognized by your machine oftenits DEL key. AT the boot sequencegive first booting option to CD Rom and second to the hard disk, save settingand exit. Boot system with Windows CD, apply option for fresh copy. AND if youhave already been done and failed. Boot computer with Windows 98 CD. Apply bootcomputer with CD Rom support. At the DOS prompt FORMAT DRIVE C. Restart yourcomputer and boot with windows XP CD.
Sep 24, 2010 | Microsoft Windows XP Professional With...
In ASUS Eee pc 901 i had ubunt and tried to install win xp h.ed sp1 included from usb,win copied fails and restart the comp and it tells NTLDR is missing press any key to restart tried whid and whidout...
XP has a problem installing directly from (non cd) usb devices by default. try it with a usb external cdrom and an actual windows cd (known to work) or reinstall ubunt and run windows as a virtual machine or if you are really into computers and really really need to install xp from usb try the link below. (good luck)
Aug 24, 2010 | ASUS Eee PC 900 Notebook
I got it from a friend and when i power it up it will boot to thw windows xp logo but i get the blue scren of death and it restarts. i go into the bois to run a winpe disk and it finds no problems
The BSOD error would have helped in the diagnostic. In all probabilities a driver is corrupted. Boot in Safe Mode and uninstall all of them. Reboot normally , if the BSOD appears again then the problem is in one of the default ones and this time only a Repair install will fix it.
Jun 17, 2010 | Acer Aspire 3000 Notebook
Computer wont install windows strange problems ensue.
are you pressing any key to boot from the cd when you get that message??
after windows finishes copying all the installation files during the first stage (dos mode) of the os installation you get a reboot, after the reboot, you should get that message that says press any key to boot from the cd, DON'T PRESS ANY KEY (or you will start again), leave it cd in.. just don't press any key... hopefully the installation process will continue on it's own onto the next stage (graphical mode).
if the computer just goes back to the dos mode without you pressing anything the problem may actually be a real problem and it may require further troubleshooting..
see how that goes with the first suggestion and post back if needed.
good luck
Nov 15, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
R3000 Compacq laptop wont boot up
Can you please give me full details on what the problem is, the BSOD, does it appear after the boot is finished and loading the OS?
Does the OS start and then get the BSOD, ETC.
If You have the original install cd, enter your bios and at BOOT DEVICES [OR BOOT SETTINGS] make sure that the first device to boot from is your cd/dvd etc, Put The Cd of the OS in the cd/rom and restart the machine, it will hopefully start the instalation of windows do not tell the program to install a fresh copy, but rather use the R for repair.
If that does not work or you still have problems it sounds like it's time for a new instal of windows, the BSOD [Blue Screen Of Death] pops up when files get damaged, if you overclock without checking everything voltages, fans, TEMPERATURE of CPU etc.
Also can you please tell me how long ago the system was activated, and what if anything did you do or were working on when you got this BSOD.
What the OS you are using is can help also, and is it sp1? sp2? sp3? for win XP even vista is up to SP1 already for a supposed new os from ms.
Dec 21, 2008 | Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
Oct 12, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Server Standard 2003 for PC Logo
165 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
