Question about Kenwood DDX-6019 Car DVD Player
I went out to my truck and started it up and no deck would turn on and my amps were not working i checked the fuses in the truck and power wires and they all are fine could it be a fuse in the deck it self.had no problems with the deck since we bought the truck 4 years ago and hints or answers.that could be of some use to me. thank you
  • 3,267 Answers
Make sure you have put the parking brake, 'cos it will work only if the parking brake is in position
Posted on Dec 29, 2010
How do you replace the selenoid and 15n amp fuse on a Craftsman Lawn Tractor - 19.5 turbo twin
First see start is good, its on under right dash panel to back of motor. Use a ohm meter, check power to solnoid, show 12v on other side with key being turn to start-12v, If not check the wire or two. If 3 wires reground sol. to frame.
May 25, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tried hooking subs and amp to my factory deck in my 2006 chrysler town &country limited.. Everything was working but wife's friend started while I was wiring smelled like burning electrical.. Now no s
Only fuse you need is the power wire leading to your aftermarket amplifier for te subwoofer. Which most likely you have too small of a gauge of wire and burned straight through it, and if you haven't, add a 40 amp fuse near the battery where your power cable is hooked up to. Also use a multimeter to test your power wire on amp, check the
Jul 19, 2013 | Car Audio & Video
Everytime I cut it on. It cuts back off like there is something wrong with it
If you turn it on and it clicks right back off you may have a short. Make sure the wire panel does not have any straggler wires going from one connector to another. Also you may have a very weak fuse. Check the fuses in your amp and at the battery terminal. Make sure the power, ground and remote wires are solidly connected. Make sure that ground is tight. Is the deck shutting off at the same time your amplifier does? The remote wire off the deck powers that amp so if the deck is also cutting out the problem may be the deck and not the amp. If this is the case then run through the steps I listed above but with the deck as well.
Regards, Tony
Mar 24, 2011 | Sony XMGTX1852 Car Amp
I have a 1976 kenwood am fm stero receiver, the stero works great but just recently the face and power single lights went out, is their a fuse inside. I open the cover and did not see one.
A stereo or amp, either one should have a fuse, fuses for radios would be in the wiring harness behind the radio deck. An amp fuse should be obvious were they insert in the fuse blocks by the amps main power cable connector. If you see that all fuses are fine then check your ground wires if not then your radio is bad.
Jun 19, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Car subwoofer amp powerup problem, insufficient remote voltage
Your deck sends 4.5 volts only through the rca jacks to send musical information to the amp,which is a good musical signal. On the rear of the deck there should be a blue wire called a remote turn on( or antenna or amp turn on ). Any of these wires send a 12 volt signal to whatever you hook them up to. run a wire from any of these wires that were just mentioned to the remote terminal on the amp, whenever you turn on the deck it should turn on the amp now. If for some reason your deck does not have any of these wires you can run a wire to the fuse box and pull the fuse that is designated for the radio-twist your wire over one prong of the fuse and insert the fuse back into its spot and turn your vehicle on- you may need to reprogram your radio but probably not depends on how you have it wired up-anyhow in this configuration every time you turn on the key to the acc or start it up it should turn your amp on .
Jan 25, 2010 | Car Audio & Video
Constant Power wire draining battery HELP!
Okay, I think I have it. The red and yellow wire into the deck need to be connected to two different power sources.
The red wire should only be hot when the accessory switch is on. The yellow wire is for constant power to maintain memory in the deck.
Connect the red wire to a source which is only hot when the ignition switch is in accessory position -- that should solve the problem.
May 06, 2009 | 1984 Lincoln Town Car
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
Amp won't turn back on, all fuses fine, all connections good
that sounds like the amp might have a bad ground.
Mar 15, 2009 | Kenwood Car Audio & Video
Prot. light at High vol. (forget Bass CD)
You may have the speakers wired for the wrong impedance.
How many ohms per voice coil?
How many voice coils per speaker?
If the speakers are DVC, are the coils of each speaker wired in series or parallel?
Are the speakers bridged on the amp or one per channel?
Jul 06, 2008 | Lanzar VIBE266 Car Audio Amplifier
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kenwood DDX-6019 Car DVD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
