Question about Microwave Ovens
What is the wattage for magic chef microwave model mcm1290a???
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
  • 958 Answers
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Posted on Feb 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: my microwave magic chef mco160uw
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you have a failed keypad.
This can be dangerous, and you should keep it attended to when in use (as with any microwave) and unplugged when not in use.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
Posted on Aug 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
Posted on Nov 27, 2008
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Posted on Mar 02, 2009
I need to know the wattage of my magic chef oven model 6898VV
Hi Nadia,
There's little to be found on the internet for this model oven now. There should be a name plate / manufacturer's sticker either inside the door - on the jamb; or on the rear near the power cord. If you see a rating given as "120VAC / 1200W" this would indicate INPUT wattage, which would be higher than the amount used for cooking. A typical 1200W rated microwave might have 800 - 1000 Watts of cooking power. If there are 2 ratings for wattage like 120V / 1200W / 850W; the 850 Watts is the amount of cooking power. The cooking power - or wattage - is always lower than the total wattage. If you see a rating somewhere that indicates 900W cooking power, then that would be the cooking power of the oven.
If you're not satisfied or unsure about the information you're finding on the oven - or it is missing - you might want to contact Magic Chef Customer Service Department at (888) 775-0202. They should be able to help you - or pint you in the right direction.
Apr 07, 2014 | Magic Microwave Ovens
Magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Nov 29, 2013 | Magic Chef 1-1 Cu Ft Microwave Oven -...
What is the watage of my magic chef microwave Model MC-1004B?
I would refer you to Magic Chef Customer Support.
Oct 08, 2011 | Magic Chef CMV1000B Microwave Oven
Completely shut down in the middle of microwaving. Checked plug and breaker. Both are fine.
there are still thermal fuses inside. one is plastic covered placed beside the transformer.
Feb 25, 2011 | Magic Chef MCM1290A Microwave Oven
When I ask for a Galanz microwave oven manual you send me anywhere except to the manual. WHY?
To download information on Galanz products go to this site:
http://www.galanz.com/Download.aspx?ColId=110&SecId=117
The Magic Chef site for microwave ovens is here:
http://mcappliance.com/microwaveovendetail.aspx
Unfortunately I did not see the model number you provided listed here. However they do provide manuals for their products and if you select a model that is similar to yours you might find the available manual to be useful.
Feb 02, 2011 | Magic Chef MCM1290A Microwave Oven
My magic chef microwaves is lock. how do i unlock it
On many Magic Chef models, press the Help button to bring up the menu. Choose the number for Child Lock (I think it's #1), then choose 2 to turn Child Lock off.
Dec 02, 2010 | Magic Chef MCM660A Microwave Oven
I've lost the book - how do you cook something at less than 100% power?
Hi, if you hit the Power button repeatedly, it will drop the power by 10% increments.
Apr 05, 2010 | Magic Chef MCM1290A Microwave Oven
Will run but not heat , majic chef, model mcd990arw
check the door switches ... they are probably burned preventing preventing the machine from knowing the door is closed.
Oct 19, 2009 | Magic Chef MCM1290A Microwave Oven
WATTS
The output power is 1000W and that's near the high end for a consumer microwave. Hope this helps.
Please write back with more details if you need further help.
We do appreciate your very thoughtful rating of our answer.
Nov 25, 2007 | Magic Chef MCM660A Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
