Question about D-Link (R) Xtreme N Duo(TM) DAP1522 Wireless BridgeAccess Point (83105J)
Im trying to use the dlink dap-1522 as an access point for my already created network. The network is WEP protected, and when I plug the dap-1522 into the computer i can edit settings, but i cannot use it as a wireless access point to boost my signal to my laptop across my house. I don't understand what to do. I've read through the manual.
  • 108 Answers
Maybe the wireless configuration of your dap1522 is not configured already.
Posted on Jan 03, 2011
How to assign static IP of my access point DAP 1150 to my pc
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
Jul 12, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
JE NE PEUX PAS INSTALER DAP 1360
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
Feb 16, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
May 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap-1522 setup wizard
You can download the latest version of the firmware you need below. Just determine if you have dap-1522 or dap-1522 rev.B.
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. Example picture on the bottom of this page.
latest dap-1522 firmware:
ftp://ftp.dlink.com/Multimedia/dap1522/Firmware/dap1522_firmware_141b.bin
latest dap-1522 revB firmware:
ftp://ftp.dlink.com/Wireless/dap1522_revB/Firmware/dap1522_revB_FW_203b.bin
Install instructions for the firmware are on page 41 in this pdf:
ftp://ftp.dlink.com/Multimedia/dap1522/Manual/dap1522_manual_130.zip
Here is a great setup video for it:
http://www.youtube.com/watch?v=lYJPGqtyFZU
Jun 05, 2012 | Computers & Internet
DAP-1522 WIZARD
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. See the example picture on the bottom of this page.
Cant open the link to setup the router
Refer to page 3 of the Quick Install Guide listed on the web site below.
There are multiple ways to configure this router and do not wish to provide HOW TO without knowing how you have it set-up.
www.dlink.com/products/default.aspx?pid=DAP-1522&tab=3
Apr 04, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1522 up as a wireless bridge. My current internet provider is Verizon Fios using their router. Why can't I...
Assuming that all settings are still at factory defaults... It's likely that to connect to the device through the web browser or through the app, you will have to temporarily assign your PCs network card a static IP address that is in the same range as the router (for example: 192.168.0.10). The user name should be admin and the password should be left blank. Make sure to plug your router directly to your PCs LAN port with an ethernet cable.
This article on the extremetech website explains exactly how to do what you are trying to do:
http://www.extremetech.com/article2/0,2845,2329231,00.asp
In case the previous link has too much info, here's another site that simply tells how to access the manual settings of the router through the browser: http://www.paraesthesia.com/archive/2010/05/04/connect-to-the-d-link-dap-1522-access-point-configuration-manually.aspx
If you go through these steps and still can't communicate with the device, it's likely that router's default configuration has been modified and you will have to reset the router to factory settings to get it back to the defaults. Then you may proceed as listed above.
To reset (if necessary) follow these instuctions on the D-Link website:
http://www.dlink.cc/d-link-wireless/d-link-dap-1522-forget-password-you-will-have-to-reset-it-to-factory-defaults.html
I know it's a lot of stuff, but I hope this helps. It can be frustrating, but you'll get through it.
Steve G.
Mar 01, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link (R) Xtreme N Duo(TM) DAP1522 Wireless BridgeAccess Point (83105J) Logo
276 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
