Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Freezer not freezing on m,aytag mfd2560hes
Freezer section not getting cold enough therefore its not making ice, every 2minutes or so i hear a humming sound for 10 sec and a click , as if a fan is trying to go on and its stuck or something. its a little cold but not enough. please help, also would it be under warranty. thanx
  • 2 more comments
  • andy singh Jul 07, 2008
    thank you very much
  • Newretiree Sep 10, 2008
    The freezer section of my Maytag MFD2560HES is defrosting everything that was frozen but the fridge seems okay. Does this mean the compressor is okay (compressor covered by a 5 yr warranty)? What could be the problem? Any help is appreciated. Thank You.
  • chppr525 Jan 11, 2009
    i have the same problem with the freezer on my maytag MFD2560HES. had a repair man come out today (1/10/09) and he said it was my compressor. repair man said it was a batch of bad compressors and it looks like we got one of them. he's checking to see if we are still under warranty for this problem
  • Anonymous Mar 04, 2009
    I have exactly the same problem. I've heard that the compressor is under warranty from Maytag for five years.
How about changing the relay, is it hard to do on the maytag
Posted on Jul 08, 2008
  • 958 Answers
Hi andy, based on your story, i think the humming sound is coming from the compressor trying to start and the clicking sound is when the overload trips and make that clicking sound to turn off the compressor but it does resets itself so it would humm again after a few minutes and tripps off again..try to unplug the unit for a day to cool off the compressr and then plug it back. if it will happen again, you need to replace the compressor. i hope i was able to help..
Posted on Jul 07, 2008
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
My Emerson ice maker, will make the 1st round of 9 ice cubes, then it fills back up with water and makes a clicking noise and won't freeze anymore cubes I'm so sad, I don't have money to buy a...
If it won't freeze the cubes that because the freezer section is not cold enough to freeze them. the ice maker itself dose not have any cooling in it. it all comes from the freezer. sounds to me like there may be a problem with the ice maker and it may need to be replaced.
Aug 05, 2013 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
I don't have a problem but I would like to know how to set my Dandy refridgerator.Its an upright small fridge.the knob only I see is in the fridge part.I don't know how to set the freeser part .There is...
Compact refrigerators that have a freezer compartment do not have seperate controls since they are cooled by the same evaporator and it is not designed to reach true freezer temperatures. It should get cold enough to freeze water for ice. If it were allowed to get much colder there would be problems preventing the refrigerated section from getting too cold. Therefore, you will have to find a setting that provides a good compromize. You should be able to keep frozen dinners and such cold enough to prevent them from thawing but I would not store meats too long in that freezer and ice cream will get soft. I hope this answers your question. - Subdriver
Feb 03, 2010 | Refrigerators
Both the refrigerator and freezer are set to the recommended temperature, however, the refrig unit is making a loud humming sound. This sound stops when you open the door, but begins again when it is...
There is a fan that blows cold air into the refrigerator. It usually stops when the door is opened. Check to see if it might be frozen with ice if the humming sounds abnormally loud. Usually if it freezes up you cannot hear the fan running and the refrigerator will not get cold enough.
Aug 25, 2009 | Refrigerators
Fridge does not keep cold, but freezer is over freezing, icemaker not making ice also.
You should be able hear, and feel the air from, a running fan inside the cabinet, in either side. The common arrangement is having the coils located (behind the wall) in the freezer section and then the fan moves a controlled amount of the frigid air to the refrigerator section via openings located in the rear of the compartment. The vents are normally adjustable so the temperature can be balanced between the two compartments.  If there is no noticeable air coming from this vent, then the fan has died.
May 25, 2009 | KitchenAid KSRS25ILSS Side by Side...
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
266 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
