Question about ViewSonic ViewMate CW2206 DHCW2206 Keyboard/Mouse
ViewSpmoc Viewmate CW2206 out of function.
It out of function just use for one month wven change battery.
I installed a new Honeywell RTH74/75 series thermostat and it has the incorrect day displayed.
Yes it will reset itself when you do that, it really should not be too hard to figure out the day.
Apr 14, 2015 | Honeywell Electronic Programmable...
Changed batteries on keyboard and now wont sync. Cant see a sync button on the keyboard so dont no wat to do
Hi.
You should find the sync/connect button underneath the keyboard. You must also press the button on the receiver.
Regards.
Jun 08, 2011 | ViewSonic ViewMate CW2206 DHCW2206...
Car won't start wven with a new battery, When turning on the ignition, there is now sound coming from the battery or starter.
Check connections at battery, if they are clean and tight, then check the ground cable where it connects to the block of the engine or fuse box under hood, clean these with a little sand papaer and replace, but it sounds more like a ground issue.
Oct 07, 2010 | 1990 Dodge Dynasty
Keyboard is locked up. Looks like Function Keys
is scroll lock on? if so turn it off and engage number lock.
Aug 29, 2010 | ViewSonic KP202, VIEWMATE OFFICE KEYBOARD...
ViewMate Keyboard: when I press shift 2 I get inverted comma. donot w...
you need to change the keyboard lay out install US if the machine is from US and UK if bought in the UK goto regional settings etc
May 16, 2010 | ViewSonic ViewMate Keyboard
Number pad on the side is not working
Press the numlock key above the 7 key. If that doesn't work, you may need to go to the manufacturers website and download a new driver for the keyboard.
Dec 02, 2009 | ViewSonic KP202, VIEWMATE OFFICE KEYBOARD...
Mouse Stops Responding
You need to reset the mouse and keyboard to the sensor. On the sensor(base) you should have a button and under the mouse you should have also a button. Press the sensor(base) button first and quickly the one under the keyboard and mouse. If the doesn't work shut down the system, unplug the mouse and keyboard sensor(base) and re-plug it back in . Start the system and try the process again.
Oct 03, 2009 | ViewSonic ViewMate CW2206 DHCW2206...
How can i get a river for my viewmate desktop
You can download the driver and software for the mouse here >>>>>
http://www.soft32.com/Download/Free/ViewMate_Desktop_Mouse_CC2201/4-172612-1.html
Regards.
Jul 29, 2009 | 3M em500gps Mouse
Boot Manager
Did you enable USB Legacy support in the bios?, if not, that should fixit
Sep 06, 2008 | ViewSonic ViewMate CW2206 DHCW2206...
Not responding to movement
Dear Stef, First try replacing the mouse's batteries, if this fails then try resetting it using the reset button - both on the mouse and the receiver. If you experience trouble resetting, you may try to disconnect the receiver and the mouse physically. Unplug the receiver and take off the mouse's batteries and then reconnect them.
Jan 09, 2006 | ViewSonic (CW2206) Keyboard
ViewSonic ViewMate CW2206 DHCW2206 Keyboard/Mouse Logo
56 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
