Question about Kenmore Brew 'n Wave 63992/63999 Microwave Oven
Looking for part #3550w1a231 ks1 2003 06
What years was the Panasonic NN-C994S convection/MW oven manufactured? Main issues to look out buying a used one?
Look at the instruction manual for manufactured from date.
If it works, it works. Nothing common to look for.
Dec 05, 2017 | Panasonic Microwave Ovens
Where is light bulb on magic chef microwave oven model # MCM990ST?
Free User Manuals and Owners Guides ManualsOnline com
good evening, this site is a good place to look, in case the manual is not to be found. I got my washing machine manual there, after having looked for the printed one without success.
kolbrun
Feb 01, 2015 | Magic Chef Microwave Ovens
Display window dim
I would open it up and look at the connections to see if any can be replaced. Look for any darkened or burned looking connectors related to the display panel. Hopefully you won't need to replace the display panel circuit board but if you do. I would look for the cheapest replacement starting with ebay parts, and search engines for that specific part. Sometimes there are microwaves of different models with the same parts too!
Nov 07, 2013 | Maytag MMV4205 Microwave Oven
Kitchen aid micro wave change fuse
Unplug, remove top, look under keypad, follow wires to circuit board, look for a silver rectangular capacitor, "may be under a plastic flap" discharge capacitor with a screwdriver across the 2 points, look for a small fuse near by in clips, remove and replace with same current rating, assemble before test because lethal voltages present when powered.
Mar 11, 2012 | KitchenAid KHMS2050SSS Microwave Oven
Model SCR 05 120V, 60Hz, 35W. Looking for a manual
Hi, can you please give more details about the manual your looking for?.. The information you gave is not enough for me to provide a manual for the product your looking for ..thanks......
Apr 08, 2011 | Microwave Ovens
My dishes are dirty after the wash. The glasses have small particles dried on the inside. They are upside down. How does it do that? Thanks.
Thanks for using FixYa.
An answer for your question about your dishwasher could be that your jets or spray arms are clogged.
1. Please look inside the dishwasher for obvious obstructions and turn the spray arms to make sure they move freely.
2. Now look at the bottom sprayer and at the little holes. If you see food or stuff in any of the holes, use small tweezers to remove.
3. Also look in the bottom area for items which may be blocking the water delivery hole.
4. Finally, look at the top sprayer arm. Using a flashlight, look closely for food or other particles which may be clogging the holes.
Let me know if this helps or if you have questions.
Thanks again for using FixYa,
Apr 03, 2011 | Microwave Ovens
HELLO,I have a sharp microwave R314FS every thing works just fine but it appears that my light bulb has blown out is it possible that i can change it myself,if so it look like i would have to remove the...
Looks like you just have to take off the outer cover. From the parts diagram I looked at this looks like a counter top unit. If so, unplug the unit and then remove the outer cover and then locate the lamp and replace it. Looks pretty easy to get to.
Oct 04, 2017 | Sharp R-314FS Microwave Oven
I have a problem with my microwave it is not warming things evrything looks fine the counter is also working but If you put something to warm it up it comes just the way you put
you may want to look at the magnetron inside the unit...this is what heats the food... there also sometimes a fuse attached to the magnetron it looks like a round disk with 2 wires attached to it normally the size of a quarter or a little smaller. it attaches to the magnetron which is a square looking metal object with wires coming off of it also... one of the 2 most likely the culprit...good luck to you
Jan 09, 2011 | Microwave Ovens
I am looking for a manual for a microwave it is a sharp carousel model R-380C.
go to the sharp site and look up your model #. they should have it for you there or be able to get one close to what you have.
Apr 09, 2009 | Sharp Microwave Ovens
Flashing red lights
It sounds like you are talking about the indicators as shown and explained on page 7 of your owner's manual.
The one that looks like windshield wipers (#10) is the microwave indicator. The ones that look like bowls of soup are the High Cook and Low Cook indicators (#24 & 25).
If you don't still have your owner's manual, you can download it here free. You will need the free Adobe Reader to view or print it.
Once you've looked that over, feel free to write back with specific symptoms if you're still having trouble.
Aug 04, 2008 | Emerson Black Microwave Oven
Kenmore Brew 'n Wave 63992/63999 Microwave Oven Logo
73 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
