Question about Sony Ericsson K800i Cellular Phone
Battery problem for my k800i
Why is it if im going to charge my cellphone, there's a warning note appeared like this one "error charging stop charging!" what could be the problem?is it my battery or my charger?
Thanks for reading my letter.
    Sergeant:
  • 234 Answers
If charge down in 3 hours mean battery problem. if the mobile show "not charging" message mean charger problem.
Posted on Jul 07, 2008
Charging hiting
what model of cellphone you have... and what heated up is it the charger or the cellphone.. we have two problem either the cellphone or the charger.. but i will tell you to look for another charger where we can check your cellphone. A charger must stop charging when the battery reaches its peak of charge... if the charger doesn't stop charging even the battery is charged then it will cause over heating to the charger or to the cellphone...
Sep 22, 2013 | Cell Phones
My sony ericsson k800i does not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 20, 2012 | Cell Phones
Charging error.stop charging my sony ericsson k800i
As if your using sony ericsson K800i some mobile phones as this problem as myself also faced the same problem sony ericsson mobile shows this error if you charge your mobile using connector or unsupported charges.You visit your nearest service center of sony ericsson and ask then to give branded sony ercsson charger for your mobile.After taking that charger you will not face this problem any more..your mobile is just perfect as new.Your connector or charger is having some problem with it. Charger may cost you around 300 rs. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 12, 2011 | Sony Ericsson K800i Cellular Phone
Dear Sirs, I'm using Sony Ericsson K800i cell phone. As soon as I put the phone into charger it displays:"Charging Error. Stop Charging!" I thought it may be battery problem and bought new...
Hello!
If you have bought new battery, and still not working. You can consider that the faulty is in the charger adapter. You can bring your phone to a service center to further check the charger and/or the circuitry of your unit.
Regards, fossildude
Nov 15, 2010 | Sony Ericsson K800i Cellular Phone
"Charging Error Stop Charging" This message keeps poping up when im trying to charge may k800i cp
Hi
There are so many problem that can cause this.
It may be the charger or the battery. so please try get a friend charger and battery and test it with your phone.
If the problem continue, you will go to sony service centre...they will re installed the software and everything will be fine.Its just a software problem....they will fix it in just 15 mins.
Thanks.
Aug 12, 2010 | Sony Ericsson K800i Cellular Phone
Sony ericsson K800i displays "charging error. stop charging"
hallo everybody i have this problem now.my k800i saying same thing.what i must do .it is not very dangerous.mayb it begun after the last firmware update.help il love my k800i and i dont want to lose it
Apr 18, 2010 | Sony Ericsson K800i Cellular Phone
Phone off after the charging and coming error message "charging error stop charging"
Replace your phone battery. If problem persist, I suggest you bring your phone in cellphone repair center. It should be handle by qualified technician.
Dec 14, 2009 | Sony Ericsson V640i Cellular Phone
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Charging error, stop charging! with "!"
I have had this problem before so dont worry, i found that i had to take out the chip and batery and air it out aswell as the the place were the charger fits, place them back in and try to charge up again.
Dec 28, 2008 | Sony Ericsson K800i Cellular Phone
K800i sony ericsson not switching on
your phone software program is damage or over DL'
the best way to do is bring to the nearest Cellphone repair shop' and re-program it' special gadget and software is needed...:D
May 26, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
251 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
