Question about Kenmore Washing Machines
Does my machine have a fabric softener dispenser? It is model number 110.24292300. SER: CS1434409. Type: 107
    President:
  • 3,113 Answers
Not that I can find!
Posted on Dec 29, 2010
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Lost manual to maytag legacy series. how do i remove softener dispenser and/or agitator for cleaning and what is the "finger faucet" switch for?
Methinks you need a manual again;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Apr 08, 2011 | Washing Machines
I have a Bosch Nexxt washer, model number WFMC 32000C/01. Yesterday I noticed the fabric softener was still in the dispenser after the cycle was completed. I cleaned out the dispenser and ran another...
Could be the fine holes in upper dispenser are blocked. Remove soap dispenser drawer and use a washing up brush to clean upper dispenser, replace drawer & test. If not could be upper dispenser or inlet valve.
Jan 10, 2011 | Bosch Washing Machines
Fabric Softener Dispenser Broken
Part # 8566491 it runs around $50.00 and it just snaps into place you can find/order at http://www.whirlpool.com/catalog/parts_and_accessories.jsp  Or any local appliance parts distributor you can find in the yellow pages.
Sep 13, 2009 | Washing Machines
Fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
Apr 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Front load washer
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
Mar 22, 2009 | Frigidaire GLTF1670A Front Load Washer
If you cannot get the dispenser cap opened, submerge and soak it in some hot water. Liquid fabric softener is a type of wax that, over a period of time, will harden and clog the dispenser (as you well know by now). In many cases you do not have to take it apart if you just use the hot water method. You may have to rinse and repeat several times. Try this and let me know if you have any luck. If you require further assistance, please post back with your complete model number, so I can see what type of dispenser cap we are talking about. I hope this helps you.
Aug 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Fabric softener not draining during rinse cycle
What type of water hoses are hooked up to it? If you have the flood safe hoses with the check valve in them then there isn't enough water pressure to distribute the softener.
Apr 25, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
